Using Kiauh, Klipper install fail, greenlet package
Host: Linux PC
Printer: Ender 3 v2
Issue: klipper install using Kiauh
Distro: Debian XFCE
Installing klipper fails when Greenlet package is supposed to install, i can’t find out how to fix or work around it. Does anyone know how?
Same issue here.
Did you find a workaround?
I changed linux distro, to Xubuntu. The install had zero problems with that distro.
For this all happens during the install of Klipper using Kiauh, this seems not to be a issue with Klipper but more with Kiauh.
You may get better help there:
It really is strange, but changing distro from debian to xubuntu, was the first working option i found.
That is strange. Ubuntu (xubuntu) is based on debian. Very strange, indeed! Any idea, why?
I am a linux noob, so i am going in completly blind. Tried first to reinstall the packages, that did not help, i then tried a reinstall. The only thing that worked was changing the distro in the end.
