dgd
1
Printer Model: None
MCU / Printerboard: BTT SKR2
ERROR: Unable to open config file /home/pi/printer.cfg
I’m using Octoprint and the printer is connecting through ‘tmp/printer’ port.
When I enter a command (M119) in the Octo terminal I get the error Unable to open config file /home/pi/printer.cfg.
The file is present and here is the info on it.
pwd
/home/pi
ls -all
-rwxr-xr-x 1 pi pi 3296 Feb 5 17:00 printer.cfg
What extremely simple thing am I missing?
Posting your klippy.log as instructed by the issue template.
dgd
3
That is all that’s in there. Multiple times.
What did you use to install Klipper on OctoPrint. There are various possibilities.
Most easy is using the OctoKlipperPi image.
dgd
6
I’ve moved past this issue, but now have a mcu 'mcu': Unable to connect error.
I’m using a BTT SKR V2 REV B board with an STM32F429.
Klippy.log klippy.log - Pastebin.com
Here’s the output of sudo dmesg sudo dmesg - Pastebin.com
Printer.cfg printer.cfg - Pastebin.com
A business trip will now take me away from this for about a week.
Thank you for the help.
Could you please upload your logs here?
Pastebin is a pain to read. And I do not need another file server on my list.
Klipper is not flashed to the board. You need to follow the installation instructions.
