Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
…The heater problem started a month ago. I couldn’t fix it so I bought a new heater and that fixed it, but now it started again, so I thought it was the temperature sensor, but when I took it out it broke. The extruder is a v6 clone from AliExpress (can’t find the link) and I need a replacement sensor can someone tell me what to buy and if the problem is in the sensor or somewhere else
You can search for a ATC Semitec 104GT-2 replacement OR buy any type you like and edit printer.cfg to match the type you purchased.
Note your photo seems to show a generic NTC 100K 3950 Thermistor. It is likely that Klipper is configured for the original hotend not the generic replacement.
