Which distribution should i use?
Printer Model: RF-1000
MCU / Printerboard: AT MEGA2560 based
Host / SBC EliteDesk 800 G1 USDT
klippy.log won’t generate one
installed klipper & octoprint on debian-13.0.0-amd64-netinst and ubuntu-24.04.3-desktop-amd64
Tried to install older versions but could not find .iso files
Can build and flash the printer.
klipper and octoprint services run.
Octoprint talks to klipper.
No activity between klipper and printer.
Can not find klippy.log in /tmp
Meanwhile spent 40+ hours on this. (retired, no problem :slightly_smiling_face: )
Still have a backup disk with a ubuntu 22… installation that still works.
Guido
Hi @Uncle_guido
klippy.log is in ~/printer_data/logs/
Did you configure your printer.cfg (located in ~/printer_data/config/)?
This is only when you install OctoPrint along with Moonraker & Mainsail/Fluidd (usually via KIAUH)
On a good old fashioned Klipper/OctoPrint install it should be at tmp/
I didn’t know that before. Thanks for pointing that out!
Thanks guys, problem solved. Nothing to do with the distribution. As soon as i found the log file it told me that the printer.cfg file should also be in a new place now. And then there was a config error due to the last Z-calibration.
Guido
