Printer Model: Custom
MCU / Printerboard: Manta M8P
Host / SBC CB2
klippy.log (2.7 MB)
Has anyone configured properly the CB2 GPIOs??
I mean, I’m trying to set their correct names but some of them don’t make sense for me.
I have taken a look at the oficial documentation of bigtreetech and have found this and some other images:
Also this is what the CB2 Manual says:
I don’t know which name take because the following:
If i try to use the first name, for example the ones as “GPIO0_B0”, klipper says that this is not a valid pin name. But for example if i take a look in the ones that are as “gpio1”, it doesn’t make sense because for example the pin 7 and pin 7 and 15 have the same name (gpio1)
Also, I don’t understand the calculation method.
The pins i’m trynig to configure are the following:
# CB2 (gpio) Pins
[board_pins CB2]
mcu: CB2
aliases:
PIN_7=GPIO3_A1,
PIN_11=GPIO0_C7,
PIN_12=GPIO0_B0,
PIN_13=GPIO1_A0,
PIN_15=GPIO1_A1,
PIN_16=GPIO4_C6,
PIN_18=GPIO4_A3,
PIN_26=GPIO0_A6,
PIN_28=GPIO0_B3,
# Controller fan
PI_FAN=gpio19 # pin 37 on the manta board's gpio pins
As previous reference… I’m going to use the same pins as the one I used with CB1, which are the following:
# CB1 (gpio) Pins
[board_pins CB1]
mcu: CB1
aliases:
# Motor alarm
PIN_7=gpio270,
PIN_11=gpio271,
PIN_12=gpio263,
PIN_13=gpio262,
PIN_15=gpio260,
PIN_16=gpio261,
PIN_18=gpio259,
PIN_26=gpio267,
PIN_28=gpio266,
# Controller fan
PI_FAN=gpio269 # pin 37 on the manta board's gpio pins
Also mention that I use a pcb i created for extracting these pins:
Any ideas?
Thanks!
