I have a doubt…
It is a CoreXY printer with 3 motors in z
always, before each impression I do the same procedure, which is:
1- homing
2- Bed Tilt
3- I separate in Z
4- Purge the extruder
5- And I print…
Except a few times, usually when I change some component that I run this other procedure
1- homing
2- Bed Tilt
3- Bed Mesh 7x7
4- Bed Tilt
But I think something is wrong, because I believe that, I attach the screenshot of the Mesh:
It’s normal… if you look closely there is a lot of difference between the maximum and the minimum… but the most curious of all is that it forms like an inclined plane. Why hasn’t Bed Tilt corrected this a bit? If the side that is lower is raised a little, the bed would not be much more “flat”, not so inclined.
