Printer Model: RepRap Anet A8 based
MCU / Printerboard: Arduino Mega
klippy.zip (1.7 MB)
Hi, I noticed this weird problem with my printer/setup after installing BLTouch. Basically my prints started to have some kind of layer shift or something like that.
Let’s assume that I want to print perfectly straight part, something like calibration cube, but my print actually looks more like that
Red line is showing how it looks in real life.
I really don’t know what might be the cause of this issue, I noticed it after installing BLTouch, but I don’t know if this is somehow connected or unusual coincidence.
This layer shift happens only in X axis. Y is perfectly straight. I checked for loose belts or loose sprockets on steppers, but they are fine.
This is my printer.cfg
[include mainsail.cfg]
# Printer Kinematics
serial: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
[stepper_x]
step_pin: PF0
dir_pin: PF1
enable_pin: !PD7
microsteps: 32
rotation_distance: 40
endstop_pin: ^PE5
#endstop_pin: ^PE4
position_endstop: 0
position_max: 214
homing_speed: 50
[stepper_y]
step_pin: PF6
dir_pin: !PF7 # Changed from !PF7 to PF7
enable_pin: !PF2
microsteps: 32
endstop_pin: ^PJ1
# endstop_pin: ^PJ0
position_endstop: 214
position_max: 214
homing_speed: 50
step_pin: PL3
dir_pin: PL1
enable_pin: !PK0
microsteps: 32
rotation_distance: 8
position_max: 150
step_pin: PA4
dir_pin: PA6
enable_pin: !PA2
microsteps: 32
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB4
sensor_pin: PK5
#control: pid
#pid_Kp: 22.2
#pid_Ki: 1.08
#pid_Kd: 114
min_temp: 0
max_temp: 250
pressure_advance = 0.125
[heater_bed]
heater_pin: PH5
sensor_pin: PK6
#control: pid
min_temp: 0
max_temp: 130
#pid_Kp: 45
#pid_Ki: 2
#pid_Kd: 290
[fan]
pin: PH6
[printer]
kinematics: cartesian
max_velocity: 200
max_accel: 1500
max_accel_to_decel: 600
max_z_velocity: 5
max_z_accel: 20
square_corner_velocity: 2.0
[bed_screws]
screw1: 30, 30
screw2: 30, 184
screw3: 184, 30
screw4: 184, 184
[bltouch]
sensor_pin: ^PD2
control_pin: PB5
x_offset: -23.5
y_offset: 1.0
#z_offset: 5
[safe_z_home]
home_xy_position: 125, 125
speed: 50
z_hop: 10
z_hop_speed: 2
[bed_mesh]
speed: 150
horizontal_move_z: 8
mesh_min: 35, 35
mesh_max: 180, 180
probe_count: 6, 6
mesh_pps: 3, 3
algorithm: bicubic
fade_start: 1
fade_end: 10
fade_target: 0
[neopixel leds]
pin: PH3
chain_count: 29
color_order: GRB
# Common EXP1 / EXP2 (display) pins
[board_pins]
aliases:
# Common EXP1 header found on many "all-in-one" ramps clones
EXP1_1=PC0, EXP1_3=PH0, EXP1_5=PA1, EXP1_7=PA5, EXP1_9=<GND>,
EXP1_2=PC2, EXP1_4=PH1, EXP1_6=PA3, EXP1_8=PA7, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PB3, EXP2_3=PC6, EXP2_5=PC4, EXP2_7=PL0, EXP2_9=<GND>,
EXP2_2=PB1, EXP2_4=PB0, EXP2_6=PB2, EXP2_8=PG0, EXP2_10=<RST>
# Pins EXP2_1, EXP2_6, EXP2_2 are also MISO, MOSI, SCK of bus "spi"
# Note, some boards wire: EXP2_8=<RST>, EXP2_10=PG0
# See the sample-lcd.cfg file for definitions of common LCD displays.
[gcode_macro SET_ACTIVE_SPOOL]
{% if params.ID %}
{% set id = params.ID|int %}
{action_call_remote_method(
"spoolman_set_active_spool",
spool_id=id
{% else %}
{action_respond_info("Parameter 'ID' is required")}
[gcode_macro CLEAR_ACTIVE_SPOOL]
spool_id=None
[gcode_macro LEDS_ON]
SET_LED LED=leds RED=0.25 BLUE=0.25 GREEN=0.25 TRANSMIT=1
[gcode_macro LEDS_OFF]
SET_LED LED=leds RED=0 BLUE=0 GREEN=0 TRANSMIT=1
#*# [extruder]
#*# control = pid
#*# pid_kp = 32.579
#*# pid_ki = 2.858
#*# pid_kd = 92.850
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 59.920
#*# pid_ki = 0.658
#*# pid_kd = 1363.929
#*# [bltouch]
#*# z_offset = 1.140
Yes I know that my printer is very, very old, but somehow I like to repair it every week ![]()
