Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
I am finishing to mount a Voron 2.4 which work nice and I decided to replace the TMC2209 with TMC 5160.
After updating the config files Mainsail starts Ok but when homing the X axis it is the Y axis which get homed and when homing the Y axis it is the X axes which moves !
I tried switching the X and Y configs (not the cables) with no succes.
The parameters for the steppers are set according to the Manta M8P V2.0 pinOut. Actually the pin configuration for the TMC5160 are identical to the TMC2209.
What could by wrong ?
to chose the drivers I want to use.
The [stepper_x]... configs are still in the printer.cfg.file (I could also move them into the tmc…cfg files) You can also find them in the klippy.log files at line 958…
I tried to swap motor A and B cables, still some problem.
Reverted to normal, motor 1 = motor B, motor 2 = motor A.
Then inverted the dir_pin of BOTH steper_x and stepper_y and then it owrk fine !
