X5SA 2E Klipper cfg
Printer Model: X5SA 2E PRO
MCU / Printerboard: SKR 3 EZ
Hello Everyone, Having an issue with configuring a dual extruder.
I have upgraded a few parts:
Motherboard to SKR 3 EZ
Dual Extrusion kit from Tronxy for the x5sa pro
My problem that the hot end is a 2 in 1. Basically 2 filaments got in hot end and only one comes out obviously. It has an extra extruder and filament sensor as well. Now the hot end is using same heater to heat both and same sensor for temp. How would i set that up?
See X-In/1-Out Non-Mixing Extruder Config
I have, however after trying the code noting happened. Plus in cura the dont have an option to name the extruder anymore so im kind of stuck there
Best thing is to ask in this linked thread for advice. I do not use such hotends so I cannot offer any more help.
