Two extruder one hot end
Printer Model: tronxy x5sa 2e
MCU / Printerboard: ramps 1.4
Host / SBC raspberry 3b+
klippy.log still in test
Error: Option ‘sensor_type’ in section ‘extruder1’ must be specified
Hello, i’m trying to set up an old printer with two extruder motor for two filament but only one hot end
all motors are controled with stand alone tmc2209
When I enable extruder1 I have a conflict with the fan pin (PH6) being used as heating pin for the extruder1.
When I remove the part maked in the config bellow there is an error
Could you help me please?
[gcode_macro T0]
ACTIVATE_EXTRUDER EXTRUDER=extruder
[gcode_macro T1]
ACTIVATE_EXTRUDER EXTRUDER=extruder1
step_pin: PA4
dir_pin: PA6
enable_pin: !PA2
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB4
sensor_pin: PK5
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 250
[extruder1]
step_pin: PC1
dir_pin: PC3
enable_pin: !PC7
################### removable par ? #############
heater_pin: PH6
sensor_pin: PK7
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 250
#conflict with precedent
#[fan]
#pin: PH6
Hello @just !
Please attach it anyway. To your next post please.
Also:
For code snippets always use the Preformatted Text feature of the form editor. Else the code is messed up and can become unusable.
Format
