Z axis noise/travel length problem
Printer Model: Ender 5 Plus Mercury 1.1
MCU / Printerboard: Manta M8P V2 W/ 2209 Drivers
Host / SBC: CB1
klippy.log:
klippy (34).log (26.6 KB)
I am doing the first checks to get my printer up and running after changing the toolhead. I noticed my calibration cube was significantly elongated on the z axis and that the best is crashing into the stepper motors because it is going to far down. I halved the rotation distance because it was double the size it should have been and was met with a very loud grinding noise, even though there was no such noise when the rotation distance was 2.
Most like wrong rotation distance and / or too high z-velocity for the given rotation distance.
See Config Z lead screw 8mm diameter, 1 start, 2mm pitch - #2 by Sineos for some lead-screw theory
