Printer Model: Anycubic Kobra Plus
MCU / Printerboard: BTT SKR 3 EZ
Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
I Just upgraded my MCU on my Kobra Plus to a BTT SKR 3 mini and it is amazing so far. Currently I have all the basics setup and the printer is running great so far. I am now looking into further upgrades to my Klipper config mainly the z-tilt adjustment. The kobra plus has the dual z steppers connected with a timing belt at the top of the z gantry. My question is, once I configure the z-tilt feature and have the z motors working independently, should the timing belt that connects the two at the top of the lead screws be removed? I’ve done some research on this and can’t find a clear answer. Thanks.
thanks for your reply. the klippy log is attached. Just to clarify, the Kobra Plus come with two independent z-motors, however the stock config has the second slaved to the first z-motor. since the SKR 3 EZ has a 5th stepper driver, I can configure the second z-motor to move independently. The configuration settings are pretty clear, it’s just that I’m not sure if I need to remove the belt at the top of the z-screws to set this feature up.
