Do you mean to use 4 steppers_z but scan only 3 points?
That doesn’t work either, if the difference between the steppers is greater, it will also be interrupted by the error “Retries aborting: Probed points range is increasing.”
I have 4 Z steppers on my Micron+ and it works fine using QGL.
For testing purposes you can use set_kinematic_position and then change whole Z to check whether all Z steppers drive into the same direction.
Furthermore my own experience shows that wrong coordinates of joint and probing points can/will cause increasing tolerances.
@Sineos has a nice drawing and article regarding to those understanding and measurements.
Hi, I keep repeating here that the position and direction of rotation of the Z stepper is correct.
I see that 4 Z steppers are complicated, so I will go to 3.
This will be sufficient to level the ground BED 8mm thick with flatness tolerance ± 0.100 mm.
Let me know if there is anything else I should try. Otherwise I will definitely redo it.
Thanks to all.
My triple-Z CoreXY mostly needs one tilting round to get below the set tolerance but if everything is correct even 4 Z motors work fine.
As I wrote it is essential for the algorithm to have correct positions of the respective joints and probing points.
Even the probe itself can influence that when it is too much at the edge of the bed or after homing its position does not really match the declared probing points…
But this applies to triple-Z as well.
Hi, I precisely measured the psition for [z_tilt] and made the adjust.
Configuration of 4 stepper Z and 3 measuring points.
I noticed that when probing there are positive and negative measurements
in the same position.
What does that mean?
Retries: 2/5 Probed points range: 0.001250 tolerance: 0.010000
Making the following Z adjustments:
stepper_z = -0.000888
stepper_z1 = -0.001773
stepper_z2 = -0.000361
stepper_z3 = 0.000525
probe at 250.000,70.000 is z= 0.000877
probe at 250.000,70.000 is z= -0.000373
probe at 160.000,265.000 is z= -0.000373
probe at 160.000,265.000 is z= -0.001623
probe at 40.000,70.000 is z= 0.003377
probe at 40.000,70.000 is z= -0.005373
Retries: 3/5 Probed points range: 0.005000 tolerance: 0.010000
stepper_z = -0.000266
stepper_z1 = -0.001360
stepper_z2 = -0.007080
stepper_z3 = -0.005986
probe at 250.000,70.000 is z= -0.005328
probe at 160.000,265.000 is z= -0.002828
probe at 160.000,265.000 is z= -0.005328
probe at 40.000,70.000 is z= 0.003422
probe at 40.000,70.000 is z= -0.004078
Retries: 2/5 Probed points range: 0.012500 tolerance: 0.010000
stepper_z = -0.004139
stepper_z1 = 0.006964
stepper_z2 = -0.002318
stepper_z3 = -0.013422
probe at 250.000,70.000 is z= -0.011023
probe at 160.000,265.000 is z= 0.002727
probe at 160.000,265.000 is z= 0.000227
probe at 40.000,70.000 is z= 0.001477
probe at 40.000,70.000 is z= -0.007273
Retries: 1/5 Probed points range: 0.011250 tolerance: 0.010000
stepper_z = -0.011477
stepper_z1 = -0.005116
stepper_z2 = 0.007023
stepper_z3 = 0.000662
probe at 250.000,70.000 is z= 0.000331
probe at 250.000,70.000 is z= -0.000919
probe at 160.000,265.000 is z= 0.001581
probe at 160.000,265.000 is z= -0.000919
probe at 40.000,70.000 is z= -0.005919
probe at 40.000,70.000 is z= -0.015919
Retries: 0/5 Probed points range: 0.014375 tolerance: 0.010000
stepper_z = -0.114689
stepper_z1 = -0.129081
stepper_z2 = -0.121937
stepper_z3 = -0.107545
probe at 250.000,70.000 is z= -0.110000
probe at 160.000,265.000 is z= -0.123750
probe at 160.000,265.000 is z= -0.125000
probe at 40.000,70.000 is z= -0.115000
probe at 40.000,70.000 is z= -0.117500
This is within the accuracy of the probe.
Hi @Sineos can you please send it to me?
Thanks
Check this:
Hi, just a question. Is it better if there is a probe or a nozzle above the “pivot point”? Because the probe has an XY offset from the nozzle
