Printer Model: Fabtotum Personal Fabricator
MCU / Printerboard:Totumduino (ramps like ATMega1280 based)
Host / SBC: Raspberry Pi
My printer is able to use different tool heads for laser engraving, milling or 3D printing.
I have set up a suitable printer.cfg for the printing purpose and have gathered quite some hours of successful printing.
Now I want to integrate the laser head as well. The head is enabled / powered by the same pin as the extruder heater. when trying to enable it (PB4 = 1) I receive an error that it is not possible for this pin.
Now I have a few things to get to work:
Remember the currently installed tool over reboot → use non volatile memory
Find a graphical solution in fluidd to switch tool heads and configure them automatically. (Don’t want to remember gcode-macro-names for rare occasions where I need the laser; 4-5 times a year) → ?
Override the heater pin functionality → ?
Regarding the last point: I read somewhere to disable config-sections by running a macro. Is this appropriate for my use or is there a cleaner/better solution?
Regarding the graphical solution: I’d love to have a dropdown with tool names in my fluidd web interface. A selection triggers a tool-configuration macro on the backend. I just don’t want to remember commands and hack them into the console. Is this even possible?
Firstly, Klipper can’t dynamically switch configs at runtime. I’d recommend creating two configs, one for your extruder, and another for your laser. Then, use [include] lines in your printer.cfg
For the heater pin, that’s likely because your heater pin is still configured as part of your extruder. I can’t tell for sure, since you didn’t upload a klippy.log
Now that I have access to the printer I added klippy.log.
Thank you for your suggestion. This is a really smart approach. I already have defined a tools.cfg for the PWM tool. But this was just meant to keep the printer.cfg “clean”.
This could be something to start with and I wouldn’t have to remember macros and stuff. Indeed this solution would be perfect, if there was a way to change the printer.cfg with fluidd gui elements. Also there should be a way to see the currently active toolhead on the control panel. If anyone can give a hint on that, the problem will already be solved entirely
