3d touch failed to deploy
Printer Model: Flyingbear Ghost 5
MCU / Printerboard: mks 1.2
Host / SBC Pine64 A64
When try to calibrate the head of printer go in wrong position and and not up the bed so the 3d touch try to pin down but crash into bed and go into error in subject.
please help me I have one printers stopped because this problem.
Thanks for all replay
klippy.log (1.6 MB)
You may provide a little more info.
What kind of 3d touch are you using? Original or clone? BL-Touch - Klipper documentation
It’s a clone 3d touch
It looks like your 3d touch isn’t configured properly.
From your klippy.log:
probe at 8.000,50.000 is z=6.906594
Starting manual Z probe. Use TESTZ to adjust position.
Finish with ACCEPT or ABORT command.
I guess you read Probe calibration - Klipper documentation?
Good luck, hcet14
I’m really Reading now I see some video and take the printer from a friend Just have 3d touch on klipper and the connect wiring Is the same. If i do the test all working but quel calibrate exit at First point with bltouch failed to deploy or probe
I have read alla documentation and do all test but the mistacke is on the connector I change the pin to control and now is perfect. Probably the pin is not managed properly by the mks robin nano V2. thanks for all reply.
