Hello,
i developed a little “extra” python module that uses an additional Fan and a Thermistor (or other temperature sensor) to heat the chamber up.
The idea is not new but i did only find macro based solutions to control the fan:
One or more fans moving air under the heatbed and transfer the heat into the chamber.
(if done properly you can smelt down the plastic parts in you chamber
Whats the difference to a macro based solution?
Not much…
- It shows up like a real chamber heater, including output of current and target temperature-
- Does wait for the bed to reach its target temperature before starting the fan, to avoid bed heater errors (I had this all the time when i started from cold)
- it needs one simple config section
- no complex startup gcode to heat up, somthing like M140 S100; M191 S50; M109 S240 (or
M140 S115; M191 S50; M104 S240; M190 S100; M140 S240 to do it a bit faster/smarter)
Current features:
- Supports M141 (set chamber temperarture) and M191 (set chamber temperarture) gecodes
- Controls temperature while printing w/o infering with the print (less than 1° cooldown of the bed, air is cirulated as slow as possible to hold the temperature)
- Waits for bed reaching its target temperature before the fan is started.
Planed:
- Using the control classes from pheaters (BangBang and PID) to control the fan speed instead of my KISS code.
- Using a compartment fan to cool down the chamber when overheated
- Complete documentation
- Some checks and failure when temperature cant be reached (e.g. difference chamber / bed temp is below a certain level on M191)
For me, the current version is enougth…
Are there people here that want this extra?
I will spend the time to make it perfect if the community is intrested and the additional time is not wasted.
mo
