Printer Model: Creality Ender 3 V3 SE
MCU / Printerboard: STM32f401 stock SE motherboard
Host / SBC : Generic amlogix s905x android TV STB using armbian 22 kernel 5.10
klippy(2).log (411.4 KB)
Hi, I just installed klipper a few days ago on my ender 3 v3 se and using an android TV set top box that I installed armbian onto. Things have been going great until I tried using klipper’s adaptive bed meshing where the printer would probe a few points then suddenly it would fail and shows this error :
MCU 'mcu' shutdown: Timer too close This often indicates the host computer is overloaded. Check for other processes consuming excessive CPU time, high swap usage, disk errors, overheating, unstable voltage, or similar system problems on the host computer. Once the underlying issue is corrected, use the "FIRMWARE_RESTART" command to reset the firmware, reload the config, and restart the host software. Printer is shutdown
I thought it could be a problem with the bed mesh process in general so I tried to calibrate it via the UI but nope, it finished without problems. I also tried KAMP plugin but the same problem occurred. Some forum posts have suggested that It’s host running out of resources but when I tried adaptive bed mesh calibrating nothing seems abnormal (normal cpu, ram, swap, disk usage)
Here’s a video showing klipper and host resource manager while running the adaptive bed mesh calibration : Watch Recording 2026-06-17 200252 | Streamable
