Need help with the new adaptive bed mesh from klipper
Printer Model: 100% custom (a kind of prusa mk3 bear)
MCU / Printerboard: Lerdge-K
My backup klipper :
Hello,
I have just started with klipper and here I am trying to make an adaptive bed mesh, I tested the first one then I came across the KAMP and I have been trying for several days to make it work, I put it in the comments 'other and when I do the command in the print_start, it systematically does the whole bed, then I see appear in videos that klipper released one and could have a conflict, I commented on that of KAMP and the surprise , the BED_MESH_CALIBRATE executes but still in full bed…
once the bed is warm I do these commands
 BED_MESH_CLEAR
 BED_MESH_CALIBRATE ADAPTIVE=1 ADAPTIVE_MARGIN=5
 SMART_PARK
 M109 S{EXTRUDER}
 LINE_PURGE
SMART_PARK and LINE_PURGE come from the KAMP part but the bed_mesh is commented out.
And here still the same behavior…
While I did everything correctly, [exclude_object] in pinter, the [file_manager] set to true in moonraker, and in orcaslicer I have the label and exclude which are checked (and exclude works)
I could turn to where for this problem? in addition impossible to modify the bed_mesh of klipper which is read-only and not included…
Hello @Acidnight !
  1. The klippy.log is more essential than your Klipper backup.
  2. If you have installed KAMP: That was not necessary. Adaptive Mesh is included in Klipper.
Hello @EddyMI3D , ok I’ll try to see how to get the logs, and for the kamp yes I suspect it but the only video that talks about it is less than a month old and I had already made my list with the flash card ^^’
So here I’m trying to make it go but I’m stuck because I’ve done everything but I still get a full bed mesh x)
