Adaptive bed meshing still probes entire bed
Printer Model: voron 2.4
MCU / Printerboard: SKR 1.4 x 2
Host / SBC RPi 3
klippy-9.log (169.6 KB)
startoffile.gcode (8.3 KB)
I posted the starting gcode of my file in the attached file
so all my settings seem to be correct, but it still probes the entire bed
thank you in advance
Do the object borders show up when you preview g-code in Fluid or Mainsail? They are in your g-code sample but your slicer could be formatting them wrong.
Try adding adaptive_margin: 5 to your [bed_mesh] section.
adaptive_margin is not an allowed setting.
So I figured maybe its cuz klipper is too old ?
turns out it hasn’t been updated for a while.
so maybe….. thats the problem.
Im gonna update it and then see again
How did you come to that conclusion?
From: Configuration reference - Klipper documentation
#adaptive_margin:
#   An optional margin (in mm) to be added around the bed area used by
#   the defined print objects when generating an adaptive mesh.
By trying to use it and failing, which is what led them to the (correct) conclusion that their Klipper install is out of date.
Git version: 'v0.11.0-248-gd725dfd30-dirty'
This is from July 2023, which is well before adaptive bed meshing was added.
