Adaptive mesh still probes whole bed
Printer Model: Homemade Delta
MCU / Printerboard: MKS Base 1.4
klippy.log - attached
I have adaptive mesh turned on however each time my prints start it probes the whole bed. I have the exclude objects on and I have the labels turned on in PursaSlicer. When printing multiple objects I can see the option to exclude an object in the Klipper UI therefore I assume this part is working ok. So I assume I have something wrong in my adaptive mesh setup?
Can anyone advise please.
Slippy log attached.
klippy-5.log (1.0 MB)
  1. Fix your START_PRINT macro:
[gcode_macro START_PRINT]
gcode =
	{% set BED_TEMP = params.BED_TEMP|float %}
	{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|float %}
	G28
	BED_MESH_CLEAR
	BED_MESH_CALIBRATE ADAPTIVE=1
	G90
	G28
	BED_MESH_PROFILE LOAD=default # <-------------------------------- DELETE
	G1 Z50 F4000
	M190 S{BED_TEMP}
	M109 S{EXTRUDER_TEMP}
	G1 X0 Y-144 Z0.3 F4500
	G3 X130 Y-75 I0J144 E25 F600
	G92 E0
	G1 E-2 F200
	M82
	G92 E0
  1. Check if you call BED_MESH_CALIBRATE elsewhere, e.g. in your slicer
  2. Check if enable_object_processing is needed in moonraker.conf
  3. Check if indeed the slicer is outputting the object information
  4. Attach a small sliced Gcode example with at least two objects if the above does not solve your issue
Thank you, this is working now. Looks like when I updated PrusaSlicer that the label objects settings changed.
Feel stupid for not checking it again but I was convinced that I had it all right.
Thanks again!
This thread can be closed now.
