Printer Model: Homemade markforged
MCU / Printerboard:octopus max
Host / SBC raspi
klippy.zip (1.6 MB)
When I print my first print after turning on the printer the adaptive mesh does work fine. It runs the mesh on the area that is defined in the gcode file.
If I load a second print file the adaptive mesh uses the previous file’s defined area.
I have the BED_MESH_PROFILE REMOVE=default and theBED_MESH_PROFILE REMOVE=adaptive running in the gcode file then also BED_MESH_CLEAR run before I run the BED_MESH_CALIBRATE PROFILE=adaptive ADAPTIVE=1 command.
If I remove the profiles and clear the mesh and run the BED_MESH_OUTPUT PGP=1 command it still shows the previous mesh definitions.
How do I clear the previous bed mesh before the second print?
I also have 4 bed heaters and if the previous adaptive mesh is bigger than the first quarter of the bed ans the second area is smaller it still uses the previous area to heat extrabed areas because it has not cleared the mesh.
Also the second adaptive mesh also uses the previous area not the area in the current gcode file.
Thanks for anyone that can help with this.
