Adaptive mesh leveling not working anymore
Printer Model: Prusa i3MK3S+
MCU / Printerboard: Einsy
Host / SBC: Pi5
klippy_adaptive_layering_notworking.log (283.2 KB)
Hello, I am using Klipper with OrcaSlicer. In the past, Adaptive Mesh Leveling was working fine but not anymore. As I recall, the problem started when I kept getting a “bed_mesh: min/max points too close together” error and no print job could be run. If I recall correctly, from the internet, I came across a post on solving it by disabling “Label objects” under Process (Global)→Others→G-code output. in the slicer. Since then, the error disappeared and I could print again. However, the printer lost the ability of Adaptive Mesh Leveling. At the beginning of each print job, the printer goes through the entire build plate to measure the level rather than just the region where the print will be made. How can I get back Adaptive Mesh Leveling and also avoid that “bed_mesh: min/max points too close together” error at the same time?
Hello, the problem still remains. Any possible way to fix this?
label object is required for adaptive meshing to work. when you disable it, klipper will do a full mesh.
Your log does not contain the error. but my guess would be that your faulty regions of your bed are causing some shifts that result in this error.
Adding a adaptive margin to your mesh command might help. Try “BED_MESH_CALIBRATE ADAPTIVE=1 ADAPTIVE_MARGIN=5“ for example.
This seems to be working. Thank you. Not sure if it is related to the “Move out of range” error which happened when I issued a M600.
