Adding palette 2s to my ender 3 v2
Printer Model: Ender 3 V2
MCU / Printerboard: 4.2.7
Hi
I’ve got myself a palette 2s and was wondering haow would I attach it to klipper. I am a newbie at 3d printing and klipper.
klippy (3).log (279.5 KB)
You may have a look here:
Is there anything I need to install. I am confused at what needs to be done
https://www.klipper3d.org/Config_Reference.html#palette2
Do I need to add that to a config folder.
Items under the Configuration Reference section goes into the printer.cfg or its own .cfg file using [include palette.cfg] at the top of the printer.cfg
Note: CANVAS hub might be required.
Ok thank you. I have created a palette.cfg and added the code from the configuration reference. Added include palette.cfg into printer.cfg.
Is there anything else I will need to do apart from add the palette serial id into the config file
Hey bud… did you have success connecting your Palette 2s to klipper? I just order a canvas Hub… but not sure if I need a Canvas Hub s(unfortunately i cannot find the Hun s for sale anywhere).
Please and thanks for you help
