After beacon calibrate and save config klipper unable to recognise default
Printer Model: Voron 2.4
MCU / Printerboard: BTT Octopus V1.1
Host / SBC : Raspberry Pi 4b
Hi
I recently installed Beacon H in my voron 2.4
The issue I have is when I Beacon_calibrate I am only allowed to use to down arrow for the Z access at 01mm. No finer adjustment is able to be activated. If I press accept the becon calibrated is then accepted. However if I then save_ config the mainsail posts a message “no beacon type registered” which means Beacon default is not accepted by klipper. I am stuck here and cannot procede.
Please attach as requested the klippy.log.
And in this case also the complete printer.cfg.
Both to your next post.
Klippy log and printer.config as requested
klippy (20).zip (9.8 KB)
# This file contains common pin mappings for the BigTreeTech Octopus V1.
# To use this config, the firmware should be compiled for the STM32F446 with a "32KiB bootloader"
# Enable "extra low-level configuration options" and select the "12MHz crystal" as clock reference
# after running "make", copy the generated "klipper/out/klipper.bin" file to a
# file named "firmware.bin" on an SD card and then restart the OctoPus with that SD card.
## Voron Design VORON2 250/300/350mm BigTreeTech OctoPus V1 TMC2209 UART config
## *** THINGS TO CHANGE/CHECK: ***
## MCU paths                            [mcu] section
## Thermistor types                     [extruder] and [heater_bed] sections - See https://www.klipper3d.org/Config_Reference.html#common-thermistors for common thermistor types
## Hotend heater pin                    [extruder] section
## Z Endstop Switch location            [safe_z_home] section
## Homing end position                  [gcode_macro G32] section
## Z Endstop Switch  offset for Z0      [stepper_z] section
## Stepper Z1 enable pin                [stepper_z1] section
## Probe points                         [quad_gantry_level] section
## Min & Max gantry corner postions     [quad_gantry_level] section
## PID tune                             [extruder] and [heater_bed] sections
## Probe pin                            [probe] section
## Fine tune E steps                    [extruder] section
[include btt_ebb-sb2240.cfg]
[include mainsail.cfg]
#[exclude_object]
#[include Adaptive_mesh.cfg]
#[include KAMP_Settings.cfg]
#[include voron_purge.cfg]
#[include line_purge.cfg]
##  Obtain definition by "ls /dev/serial/by-id/*" then unplug to verify
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_060025000E5053424E363620-if00
restart_method: command
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000             #Max 4000
max_z_velocity: 15          #Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 350
square_corner_velocity: 5.0
#   X/Y Stepper Settings
##  B Stepper - Left
##  Connected to MOTOR_0
##  Endstop connected to DIAG_0
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
rotation_distance: 40
microsteps: 32
full_steps_per_rotation:400  #set to 400 for 0.9 degree stepper
endstop_pin: PG6
position_min: 0
##  Uncomment below for 250mm build
#position_endstop: 250
#position_max: 250
##  Uncomment for 300mm build
#position_endstop: 300
#position_max: 300
##  Uncomment for 350mm build
position_endstop: 350
position_max: 350
homing_speed: 25   #Max 100
homing_retract_dist: 5
homing_positive_dir: true
##  Make sure to update below for your relevant driver (2208 or 2209)
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
##  A Stepper - Right
##  Connected to MOTOR_1
##  Endstop connected to DIAG_1
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 32
endstop_pin: PG9
position_min: 0
##  Uncomment for 250mm build
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: false
run_current: 0.8
#   Z Stepper Settings
## Z0 Stepper - Front Left
##  Connected to MOTOR_2
##  Endstop connected to DIAG_2
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
endstop_pin: probe: z_virtual_endstop
##  Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
##  (+) value = endstop above Z0, (-) value = endstop below
##  Increasing position_endstop brings nozzle closer to the bed
##  After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
#position_endstop: 0
#position_max: 210
##  Uncomment below for 300mm build
#position_max: 260
##  Uncomment below for 350mm build
position_max: 350
position_min: -5
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 0
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
##  Z1 Stepper - Rear Left
##  Connected to MOTOR_3
[stepper_z1]
step_pin: PG4
dir_pin: !PC1
## Octopus 1.0 & 1.1.  Octopus PRO 1.0
enable_pin: !PA0
## Octopus PRO 1.1
#enable_pin: !PA2
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z1]
uart_pin: PC7
interpolate: false
run_current: 0.8
##  Z2 Stepper - Rear Right
##  Connected to MOTOR_4
[stepper_z2]
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z2]
uart_pin: PF2
interpolate: false
run_current: 0.8
##  Z3 Stepper - Front Right
##  Connected to MOTOR_5
[stepper_z3]
step_pin: PC13
dir_pin: !PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z3]
uart_pin: PE4
interpolate: false
run_current: 0.8
#   Extruder
##  Connected to MOTOR_6
##  Heater - HE0
##  Thermistor - T0
#[extruder]
#step_pin: PE2
#dir_pin: PE3
#enable_pin: !PD4
##  Update value below when you perform extruder calibration
##  If you ask for 100mm of filament, but in reality it is 98mm:
##  rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
##  22.6789511 is a good starting point
#rotation_distance: 22.6789511   #Bondtech 5mm Drive Gears
##  Update Gear Ratio depending on your Extruder Type
##  Use 50:10 for Stealthburner/Clockwork 2
##  Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
##  Use 80:20 for M4, M3.1
#gear_ratio: 50:10
#microsteps: 32
#full_steps_per_rotation: 200    #200 for 1.8 degree, 400 for 0.9 degree
#nozzle_diameter: 0.400
#filament_diameter: 1.75
#heater_pin: PA2
## Octopus PRO 1.1
#heater_pin: PA0
## Check what thermistor type you have. See https://www.klipper3d.org/Config_Reference.html#common-thermistors for common thermistor types.
## Use "Generic 3950" for NTC 100k 3950 thermistors
#sensor_type: Generic 3950
#sensor_pin: PF4
#min_temp: -100
#max_temp: 270
#max_power: 1.0
#min_extrude_temp: 170
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
##  Try to keep pressure_advance below 1.0
#pressure_advance: 0.05
##  Default is 0.040, leave stock
#pressure_advance_smooth_time: 0.040
##  E0 on MOTOR6
#[tmc2209 extruder]
#uart_pin: PE1
#interpolate: false
#run_current: 0.5
#sense_resistor: 0.110
#stealthchop_threshold: 0
#   Bed Heater
##  SSR Pin - HE1
##  Thermistor - TB
[heater_bed]
##  Uncomment the following line if using the default SSR wiring from the docs site
heater_pin: PA3
##  Other wiring guides may use BED_OUT to control the SSR. Uncomment the following line for those cases
#heater_pin: PA1
## Use "Generic 3950" for Keenovo heaters
sensor_pin: PF3
##  Adjust max_power so it doesn't exceed the SSR rating. The Omron G3NA-210B-DC5 SSR is rated at 4 amps without a heatsink.
##  The formula is "4 / (Wattage_of_bed_heater / Mains_voltage) = max_power"
##  If max_power is greater than 1.0, use 1.0
max_power: 0.6
min_temp: 0
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
#   Probe
[beacon]
serial: /dev/serial/by-id/usb-Beacon_Beacon_RevH_06F0EB985154364134202020FF142909-if00
x_offset: -20 # update with offset from nozzle on your machine
y_offset: 0 # update with offset from nozzle on your machine
mesh_main_direction: x
mesh_runs: 2
[safe_z_home]
home_xy_position: 175, 175 # update for your machine
z_hop: 3
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 10, 10
mesh_max: 300, 300
probe_count: 5, 3
mesh_pps: 2, 3
algorithm: bicubic
bicubic_tension: 0.2
##  Inductive Probe
##  This probe is not used for Z height, only Quad Gantry Leveling
##[probe]
## Select the probe port by type:
## For the PROBE port. Will not work with Diode. May need pull-up resistor from signal to 24V.
#pin: ~!PB7
## For the DIAG_7 port. NEEDS BAT85 DIODE! Change to !PG15 if probe is NO.
#pin: PG15
## For Octopus Pro PROBE port; NPN and PNP proximity switch types can be set by jumper
#pin: ~!PC5
#x_offset: 0
#y_offset: 25.0
#z_offset: 0
#speed: 10.0
#samples: 3
#samples_result: median
#sample_retract_dist: 3.0
#samples_tolerance: 0.006
#samples_tolerance_retries: 3
#   Fan Control
##  Print Cooling Fan - FAN0
#[fan]
#pin: PA8
#kick_start_time: 0.5
##  Depending on your fan, you may need to increase this value
##  if your fan will not start. Can change cycle_time (increase)
##  if your fan is not able to slow down effectively
#off_below: 0.10
##  Hotend Fan - FAN1
#[heater_fan hotend_fan]
#pin: PE5
#max_power: 1.0
#heater: extruder
#heater_temp: 50.0
##  If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
##  Controller fan - FAN2
[controller_fan controller_fan]
pin: PD12
heater: heater_bed
##  Exhaust fan - FAN3
#[heater_fan exhaust_fan]
#pin: PD13
#max_power: 1.0
#shutdown_speed: 0.0
#kick_start_time: 5.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
#   LED Control
## Chamber Lighting - HE2 Connector (Optional)
#[output_pin caselight]
##Octopus 1.0 & 1.1, Octopus PRO 1.0
#pin: PB10
##Octopus PRO 1.1
#pin: PB0
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
#   Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
##  Use QUAD_GANTRY_LEVEL to level a gantry.
##  Min & Max gantry corners - measure from nozzle at MIN (0,0) and
##  MAX (250, 250), (300,300), or (350,350) depending on your printer size
##  to respective belt positions
##  Gantry Corners for 250mm Build
#gantry_corners:
#   -60,-10
#   310, 320
##  Probe points
#points:
#   50,25
#   50,175
#   200,175
#   200,25
##  Gantry Corners for 300mm Build
#gantry_corners:
#   -60,-10
#   360,370
##  Probe points
#points:
#   50,25
#   50,225
#   250,225
#   250,25
##  Gantry Corners for 350mm Build
#gantry_corners:
  #-60,-10
   #410,420
##  Probe points
#points:
  #50,25
  #50,275
  #300,275
  #300,25
#speed: 100
#horizontal_move_z: 10
#retries: 5
#retry_tolerance: 0.0075
#max_adjust: 10
# EXP1 / EXP2 (display) pins
[board_pins]
aliases:
    # EXP1 header
    EXP1_1=PE8, EXP1_2=PE7,
    EXP1_3=PE9, EXP1_4=PE10,
    EXP1_5=PE12, EXP1_6=PE13,    # Slot in the socket on this side
    EXP1_7=PE14, EXP1_8=PE15,
    EXP1_9=<GND>, EXP1_10=<5V>,
    # EXP2 header
    EXP2_1=PA6, EXP2_2=PA5,
    EXP2_3=PB1, EXP2_4=PA4,
    EXP2_5=PB2, EXP2_6=PA7,      # Slot in the socket on this side
    EXP2_7=PC15, EXP2_8=<RST>,
    EXP2_9=<GND>, EXP2_10=<5V>
#   Displays
##  Uncomment the display that you have
##  RepRapDiscount 128x64 Full Graphic Smart Controller
#[display]
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#encoder_pins: ^EXP2_5, ^EXP2_3
#click_pin: ^!EXP1_2
#[output_pin beeper]
#pin: EXP1_1
##  mini12864 LCD Display
#[display]
#lcd_type: uc1701
#cs_pin: EXP1_3
#a0_pin: EXP1_4
#rst_pin: EXP1_5
#contrast: 63
#spi_software_miso_pin: EXP2_1
#spi_software_mosi_pin: EXP2_6
#spi_software_sclk_pin: EXP2_2
##  To control Neopixel RGB in mini12864 display
#[neopixel btt_mini12864]
#pin: EXP1_6
#chain_count: 3
#initial_RED: 0.1
#initial_GREEN: 0.5
#initial_BLUE: 0.0
#color_order: RGB
##  Set RGB values on boot up for each Neopixel.
##  Index 1 = display, Index 2 and 3 = Knob
#[delayed_gcode setdisplayneopixel]
#initial_duration: 1
#gcode:
#        SET_LED LED=btt_mini12864 RED=1 GREEN=1 BLUE=1 INDEX=1 TRANSMIT=0
#        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
#        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
#   Macros
[gcode_macro PARK]
    {% set th = printer.toolhead %}
    G0 X{th.axis_maximum.x//2} Y{th.axis_maximum.y//2} Z30
[gcode_macro G32]
    SAVE_GCODE_STATE NAME=STATE_G32
    G90
    G28
    QUAD_GANTRY_LEVEL
    G28
    PARK
    RESTORE_GCODE_STATE NAME=STATE_G32
[gcode_macro PRINT_START]
#   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
    G32                            ; home all axes
    G90                            ; absolute positioning
    G1 Z20 F3000                   ; move nozzle away from bed
    bed_mesh_clear
    Bed_mesh_calibrate
    voron_purge
    line_purge
[gcode_macro PRINT_END]
#   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
    # safe anti-stringing move coords
    {% set x_safe = th.position.x + 20 * (1 if th.axis_maximum.x - th.position.x > 20 else -1) %}
    {% set y_safe = th.position.y + 20 * (1 if th.axis_maximum.y - th.position.y > 20 else -1) %}
    {% set z_safe = [th.position.z + 2, th.axis_maximum.z]|min %}
    SAVE_GCODE_STATE NAME=STATE_PRINT_END
    M400                           ; wait for buffer to clear
    G92 E0                         ; zero the extruder
    G1 E-5.0 F1800                 ; retract filament
    TURN_OFF_HEATERS
    G0 X{x_safe} Y{y_safe} Z{z_safe} F20000  ; move nozzle to remove stringing
    G0 X{th.axis_maximum.x//2} Y{th.axis_maximum.y - 2} F3600  ; park nozzle at rear
    M107                                     ; turn off fan
    BED_MESH_CLEAR
    # The purpose of the SAVE_GCODE_STATE/RESTORE_GCODE_STATE
    # command pair is to restore the printer's coordinate system
    # and speed settings since the commands above change them.
    # However, to prevent any accidental, unintentional toolhead
    # moves when restoring the state, explicitly set MOVE=0.
    RESTORE_GCODE_STATE NAME=STATE_PRINT_END MOVE=0
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.+
#*# reg_drive_current = 15
#*# [beacon model default]
#*# model_coef = 1.7411078741184864,
#*# 	  2.0282736731701902,
#*# 	  0.6862528830345038,
#*# 	  0.3486093067747865,
#*# 	  0.16530108376973393,
#*# 	  -0.12163665562446468,
#*# 	  -0.05862986736543908,
#*# 	  0.2452631713667019,
#*# 	  0.06819765879742178,
#*# 	  -0.09611906443345801
#*# model_domain = 1.9240001689671922e-07,1.94294272461105e-07
#*# model_range = 0.200000,5.000000
#*# model_temp = 22.748053
#*# model_offset = 0.00000
#*# model_coef = 1.7067806489191413,
#*# 	  2.012188591634574,
#*# 	  0.6926714877472473,
#*# 	  0.3119900200087614,
#*# 	  0.20334153899145777,
#*# 	  -0.022593663079803088,
#*# 	  -0.06994937379891607,
#*# 	  0.16887774609529993,
#*# 	  0.0722456879061055,
#*# 	  -0.06351006089271206
#*# model_domain = 1.915421321607789e-07,1.9411589290898408e-07
#*# model_temp = 17.426948
#*# model_coef = 1.7614442812018936,
#*# 	  2.0473591186310696,
#*# 	  0.7168272264936951,
#*# 	  0.39628061141359183,
#*# 	  0.01313507143947696,
#*# 	  -0.38121931711807944,
#*# 	  0.13172756012761982,
#*# 	  0.6002881682710194,
#*# 	  -0.017420273453729623,
#*# 	  -0.2545809693853755
#*# model_domain = 1.9269679204207e-07,1.9435768235056183e-07
#*# model_temp = 18.089880
#*# model_coef = 1.7055151835074758,
#*# 	  2.0126615352461403,
#*# 	  0.681363527234212,
#*# 	  0.27721032699374687,
#*# 	  0.2677438651147289,
#*# 	  0.16261667108254918,
#*# 	  -0.19160765825537743,
#*# 	  -0.12905302471922508,
#*# 	  0.1412986768176732,
#*# 	  0.08518811226089557
#*# model_domain = 1.9162979251029213e-07,1.9413117887102388e-07
#*# model_temp = 22.418298
#*# model_coef = 1.6970372354317966,
#*# 	  1.996812336360698,
#*# 	  0.7013133262000886,
#*# 	  0.2471918104863108,
#*# 	  0.19667592740612264,
#*# 	  0.2591509556382915,
#*# 	  -0.06255297032824234,
#*# 	  -0.18891323110393396,
#*# 	  0.07103259075263532,
#*# 	  0.09118200068818301
#*# model_domain = 1.9125193410486744e-07,1.9405542164927475e-07
#*# model_temp = 22.883046
#*# model_coef = 1.7138732037276572,
#*# 	  2.0034022701461596,
#*# 	  0.7041446918390303,
#*# 	  0.30667724721363016,
#*# 	  0.14930539049244385,
#*# 	  0.10751009214461864,
#*# 	  -0.006789349200466126,
#*# 	  -0.0470556392104273,
#*# 	  0.04277715934782651,
#*# 	  0.0351523927017796
#*# model_domain = 1.9175819325865713e-07,1.941554600818759e-07
#*# model_temp = 23.380527
#*# model_coef = 1.7427534471474244,
#*# 	  2.0479603806709905,
#*# 	  0.6795041008104327,
#*# 	  0.256577892886551,
#*# 	  0.21476321214624003,
#*# 	  0.15306741946285482,
#*# 	  -0.13597213587105095,
#*# 	  -0.10238405719770477,
#*# 	  0.10168745460437788,
#*# 	  0.051597440302921856
#*# model_domain = 1.9242412144881197e-07,1.943308580498378e-07
#*# model_temp = 20.624486
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 	  -0.808022, -0.685457, -0.620456, -0.537661, -0.418332
#*# 	  0.372761, 0.154378, -0.054844, -0.227493, -0.360822
#*# 	  1.362267, 0.979261, 0.539283, 0.086328, -0.130129
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 5.0
#*# max_x = 310.0
#*# min_y = 5.0
#*# max_y = 310.0
#*# model_coef = 1.6907648131225812,
#*# 	  1.9766848887014146,
#*# 	  0.7013804773249704,
#*# 	  0.34017875253421187,
#*# 	  0.16670689623999116,
#*# 	  0.017904562865218087,
#*# 	  0.004592282954174283,
#*# 	  0.07186101641119913,
#*# 	  0.03827998394000279,
#*# 	  -0.002774969253180517
#*# model_domain = 1.9093146680793573e-07,1.9402355920135718e-07
#*# model_temp = 20.789928
#*# version = 1
#*# points =
#*# 	  -0.691960, -0.606158, -0.556534, -0.469763, -0.329971
#*# 	  0.423036, 0.200318, -0.004589, -0.174587, -0.292900
#*# 	  1.412675, 1.022134, 0.585692, 0.141770, -0.056444
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 5.0
#*# max_x = 310.0
#*# min_y = 5.0
#*# max_y = 310.0
#*# model_coef = 1.682772670823201,
#*# 	  1.971610789976209,
#*# 	  0.6909513221065361,
#*# 	  0.3280226916794054,
#*# 	  0.1945783028203591,
#*# 	  0.060408184043791315,
#*# 	  -0.00899956945603164,
#*# 	  0.05116785179219562,
#*# 	  0.04154129453476751,
#*# 	  -0.006786246656079006
#*# model_domain = 1.9072210099147046e-07,1.9398653418160353e-07
#*# model_temp = 22.024338
#*# version = 1
#*# points =
#*# 	  -0.607388, -0.549764, -0.511448, -0.438259, -0.297314
#*# 	  0.412229, 0.203914, 0.012126, -0.144278, -0.254201
#*# 	  1.324851, 0.970689, 0.568767, 0.162417, -0.035212
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 10.0
#*# max_x = 300.0
#*# min_y = 10.0
#*# max_y = 300.0
#*# model_coef = 1.6866412922095426,
#*# 	  1.9736809327161986,
#*# 	  0.6807035951950957,
#*# 	  0.30613972342144596,
#*# 	  0.23130102848878253,
#*# 	  0.16004947199847477,
#*# 	  -0.07079576527962453,
#*# 	  -0.1120383520654977,
#*# 	  0.07396622433721763,
#*# 	  0.07706357059550537
#*# model_domain = 1.90739737390908e-07,1.9398956672238156e-07
#*# model_temp = 23.418544
#*# version = 1
#*# points =
#*# 	  -0.598195, -0.539282, -0.501455, -0.431144, -0.295663
#*# 	  0.409153, 0.200007, 0.008834, -0.147293, -0.259983
#*# 	  1.311845, 0.956247, 0.554468, 0.148269, -0.046679
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 3
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 10.0
#*# max_x = 300.0
#*# min_y = 10.0
#*# max_y = 300.0
#*# model_coef = 1.692625508502522,
#*# 	  1.9779147624532591,
#*# 	  0.651592476521398,
#*# 	  0.2871243223497995,
#*# 	  0.33012070899153356,
#*# 	  0.1819285534728437,
#*# 	  -0.22096522497204713,
#*# 	  -0.12649524857836372,
#*# 	  0.14836284196944036,
#*# 	  0.08391052674543667
#*# model_domain = 1.9082333987938336e-07,1.9400658866095255e-07
#*# model_temp = 20.329977
Please also the printer.cfg as a file! and not Copy & Paste.
At least use the Preformatted Text feature of the forum editor.
Format
The way you did it, the data is not usable at all.
BTW: You have 12 (!) config blocks. That can not work.
#[exclude_object]
[printer]
kinematics: corexy
max_velocity: 300
max_z_accel: 350
##  B Stepper - Left
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
microsteps: 32
endstop_pin: PG6
position_min: 0
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 32
endstop_pin: PG9
position_min: 0
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: false
run_current: 0.8
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
#position_max: 210
#position_max: 260
position_max: 350
position_min: -5
homing_speed: 8
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
[stepper_z1]
step_pin: PG4
dir_pin: !PC1
enable_pin: !PA0
## Octopus PRO 1.1
#enable_pin: !PA2
gear_ratio: 80:16
microsteps: 32
uart_pin: PC7
interpolate: false
run_current: 0.8
[stepper_z2]
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
uart_pin: PF2
interpolate: false
run_current: 0.8
[stepper_z3]
step_pin: PC13
dir_pin: !PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
uart_pin: PE4
interpolate: false
run_current: 0.8
#   Extruder
##  Heater - HE0
##  Thermistor - T0
#[extruder]
#step_pin: PE2
#dir_pin: PE3
#enable_pin: !PD4
#gear_ratio: 50:10
#microsteps: 32
#heater_pin: PA2
## Octopus PRO 1.1
#heater_pin: PA0
#sensor_pin: PF4
#min_temp: -100
#max_temp: 270
#max_power: 1.0
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
##  E0 on MOTOR6
#[tmc2209 extruder]
#uart_pin: PE1
#interpolate: false
#run_current: 0.5
#   Bed Heater
##  SSR Pin - HE1
##  Thermistor - TB
[heater_bed]
heater_pin: PA3
#heater_pin: PA1
sensor_pin: PF3
max_power: 0.6
min_temp: 0
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
#   Probe
[beacon]
mesh_runs: 2
[safe_z_home]
z_hop: 3
[bed_mesh]
speed: 120
mesh_min: 10, 10
mesh_max: 300, 300
probe_count: 5, 3
mesh_pps: 2, 3
algorithm: bicubic
##  Inductive Probe
##[probe]
#pin: ~!PB7
#pin: PG15
#pin: ~!PC5
#x_offset: 0
#y_offset: 25.0
#z_offset: 0
#speed: 10.0
#samples: 3
#   Fan Control
#[fan]
#pin: PA8
#off_below: 0.10
#pin: PE5
#max_power: 1.0
#heater: extruder
#heater_temp: 50.0
#fan_speed: 1.0
pin: PD12
heater: heater_bed
#pin: PD13
#max_power: 1.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
#   LED Control
#pin: PB10
##Octopus PRO 1.1
#pin: PB0
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
[idle_timeout]
timeout: 1800
#gantry_corners:
#   -60,-10
#   310, 320
##  Probe points
#points:
#   50,25
#   50,175
#   200,175
#   200,25
#gantry_corners:
#   -60,-10
#   360,370
##  Probe points
#points:
#   50,25
#   50,225
#   250,225
#   250,25
#gantry_corners:
  #-60,-10
   #410,420
##  Probe points
#points:
  #50,25
  #50,275
  #300,275
  #300,25
#speed: 100
#retries: 5
#max_adjust: 10
[board_pins]
aliases:
    # EXP1 header
    # EXP2 header
#   Displays
#[display]
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#pin: EXP1_1
#[display]
#lcd_type: uc1701
#cs_pin: EXP1_3
#a0_pin: EXP1_4
#rst_pin: EXP1_5
#contrast: 63
#pin: EXP1_6
#chain_count: 3
#initial_RED: 0.1
#initial_GREEN: 0.5
#initial_BLUE: 0.0
#color_order: RGB
#gcode:
#   Macros
[gcode_macro PARK]
[gcode_macro G32]
    G90
    G28
    QUAD_GANTRY_LEVEL
    G28
    PARK
    G32                            ; home all axes
    bed_mesh_clear
    Bed_mesh_calibrate
    voron_purge
    line_purge
    TURN_OFF_HEATERS
    M107                                     ; turn off fan
    BED_MESH_CLEAR
#*# version = 1
#*# points =
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 5.0
#*# max_x = 310.0
#*# min_y = 5.0
#*# max_y = 310.0
#*# version = 1
#*# points =
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 5.0
#*# max_x = 310.0
#*# min_y = 5.0
#*# max_y = 310.0
#*# version = 1
#*# points =
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 10.0
#*# max_x = 300.0
#*# min_y = 10.0
#*# max_y = 300.0
#*# version = 1
#*# points =
#*# x_count = 5
#*# y_count = 3
#*# mesh_x_pps = 2
#*# mesh_y_pps = 3
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 10.0
#*# max_x = 300.0
#*# min_y = 10.0
#*# max_y = 300.0
You still have way too many config block at the and
#[exclude_object]
[printer]
kinematics: corexy
max_velocity: 300
max_z_accel: 350
##  B Stepper - Left
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
microsteps: 32
endstop_pin: PG6
position_min: 0
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 32
endstop_pin: PG9
position_min: 0
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: false
run_current: 0.8
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
#position_max: 210
#position_max: 260
position_max: 350
position_min: -5
homing_speed: 8
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
[stepper_z1]
step_pin: PG4
dir_pin: !PC1
enable_pin: !PA0
## Octopus PRO 1.1
#enable_pin: !PA2
gear_ratio: 80:16
microsteps: 32
uart_pin: PC7
interpolate: false
run_current: 0.8
[stepper_z2]
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
uart_pin: PF2
interpolate: false
run_current: 0.8
[stepper_z3]
step_pin: PC13
dir_pin: !PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
uart_pin: PE4
interpolate: false
run_current: 0.8
#   Extruder
##  Heater - HE0
##  Thermistor - T0
#[extruder]
#step_pin: PE2
#dir_pin: PE3
#enable_pin: !PD4
#gear_ratio: 50:10
#microsteps: 32
#heater_pin: PA2
## Octopus PRO 1.1
#heater_pin: PA0
#sensor_pin: PF4
#min_temp: -100
#max_temp: 270
#max_power: 1.0
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
##  E0 on MOTOR6
#[tmc2209 extruder]
#uart_pin: PE1
#interpolate: false
#run_current: 0.5
#   Bed Heater
##  SSR Pin - HE1
##  Thermistor - TB
[heater_bed]
heater_pin: PA3
#heater_pin: PA1
sensor_pin: PF3
max_power: 0.6
min_temp: 0
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
#   Probe
[beacon]
mesh_runs: 2
[safe_z_home]
z_hop: 3
[bed_mesh]
speed: 120
mesh_min: 10, 10
mesh_max: 300, 300
probe_count: 5, 3
mesh_pps: 2, 3
algorithm: bicubic
##  Inductive Probe
##[probe]
#pin: ~!PB7
#pin: PG15
#pin: ~!PC5
#x_offset: 0
#y_offset: 25.0
#z_offset: 0
#speed: 10.0
#samples: 3
#   Fan Control
#[fan]
#pin: PA8
#off_below: 0.10
#pin: PE5
#max_power: 1.0
#heater: extruder
#heater_temp: 50.0
#fan_speed: 1.0
pin: PD12
heater: heater_bed
#pin: PD13
#max_power: 1.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
#   LED Control
#pin: PB10
##Octopus PRO 1.1
#pin: PB0
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
[idle_timeout]
timeout: 1800
#gantry_corners:
#   -60,-10
#   310, 320
##  Probe points
#points:
#   50,25
#   50,175
#   200,175
#   200,25
#gantry_corners:
#   -60,-10
#   360,370
##  Probe points
#points:
#   50,25
#   50,225
#   250,225
#   250,25
#gantry_corners:
  #-60,-10
   #410,420
##  Probe points
#points:
  #50,25
  #50,275
  #300,275
  #300,25
#speed: 100
#retries: 5
#max_adjust: 10
[board_pins]
aliases:
    # EXP1 header
    # EXP2 header
#   Displays
#[display]
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#pin: EXP1_1
#[display]
#lcd_type: uc1701
#cs_pin: EXP1_3
#a0_pin: EXP1_4
#rst_pin: EXP1_5
#contrast: 63
#pin: EXP1_6
#chain_count: 3
#initial_RED: 0.1
#initial_GREEN: 0.5
#initial_BLUE: 0.0
#color_order: RGB
#gcode:
#   Macros
[gcode_macro PARK]
[gcode_macro G32]
    G90
    G28
    QUAD_GANTRY_LEVEL
    G28
    PARK
    G32                            ; home all axes
    bed_mesh_clear
    Bed_mesh_calibrate
    voron_purge
    line_purge
    TURN_OFF_HEATERS
    M107                                     ; turn off fan
    BED_MESH_CLEAR
#*# model_coef = 1.893197358418992,
#*# 	  2.189688390099554,
#*# 	  0.6793703046731926,
#*# 	  0.07145659600327188,
#*# 	  -0.1408335310424842,
#*# 	  0.38702610626257716,
#*# 	  0.3420449523455563,
#*# 	  -0.33030962326307656,
#*# 	  -0.1595815189762197,
#*# 	  0.10740617142694256
#*# model_domain = 1.9415886291284917e-07,1.9476376064813647e-07
#*# model_temp = 15.070651
change it to
It bit more comments would be quite helpful.
I am a bit of a loss as to why i try to calibrate beacon and unable to save_config. Unless i solve this problem I am unable to progress. BTW i am a retired person in their mid 70"s using 3D printing as a way to take up my retirement. I have never asked for help before unless i really need it but have limited experience.
To use this config, the firmware should be compiled for the STM32F446 with a “32KiB bootloader”
Enable “extra low-level configuration options” and select the “12MHz crystal” as clock reference
after running “make”, copy the generated “klipper/out/klipper.bin” file to a
file named “firmware.bin” on an SD card and then restart the OctoPus with that SD card.
Thermistor types [extruder] and [heater_bed] sections - See Configuration reference - Klipper documentation for common thermistor types
#[exclude_object]
Obtain definition by “ls /dev/serial/by-id/*” then unplug to verify
[printer]
kinematics: corexy
max_velocity: 300
max_z_accel: 350
B Stepper - Left
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
microsteps: 32
endstop_pin: PG6
position_min: 0
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
A Stepper - Right
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 32
endstop_pin: PG9
position_min: 0
#position_max: 250
#position_max: 300
position_max: 350
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: false
run_current: 0.8
Z Stepper Settings
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
#position_max: 210
#position_max: 260
position_max: 350
position_min: -5
homing_speed: 8
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
[stepper_z1]
step_pin: PG4
dir_pin: !PC1
enable_pin: !PA0
Octopus PRO 1.1
#enable_pin: !PA2
gear_ratio: 80:16
microsteps: 32
uart_pin: PC7
interpolate: false
run_current: 0.8
[stepper_z2]
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
uart_pin: PF2
interpolate: false
run_current: 0.8
[stepper_z3]
step_pin: PC13
dir_pin: !PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
uart_pin: PE4
interpolate: false
run_current: 0.8
Extruder
Heater - HE0
Thermistor - T0
#[extruder]
#step_pin: PE2
#dir_pin: PE3
#enable_pin: !PD4
#gear_ratio: 50:10
#microsteps: 32
#heater_pin: PA2
Octopus PRO 1.1
#heater_pin: PA0
Check what thermistor type you have. See Configuration reference - Klipper documentation for common thermistor types.
Use “Generic 3950” for NTC 100k 3950 thermistors
#sensor_pin: PF4
#min_temp: -100
#max_temp: 270
#max_power: 1.0
#control = pid
#pid_kp = 26.213
#pid_ki = 1.304
#pid_kd = 131.721
E0 on MOTOR6
#[tmc2209 extruder]
#uart_pin: PE1
#interpolate: false
#run_current: 0.5
Bed Heater
SSR Pin - HE1
Thermistor - TB
[heater_bed]
heater_pin: PA3
#heater_pin: PA1
Use “Generic 3950” for Keenovo heaters
sensor_pin: PF3
Adjust max_power so it doesn’t exceed the SSR rating. The Omron G3NA-210B-DC5 SSR is rated at 4 amps without a heatsink.
The formula is “4 / (Wattage_of_bed_heater / Mains_voltage) = max_power”
max_power: 0.6
min_temp: 0
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
Probe
[beacon]
mesh_runs: 2
[safe_z_home]
z_hop: 3
[bed_mesh]
speed: 120
mesh_min: 10, 10
mesh_max: 300, 300
probe_count: 5, 3
mesh_pps: 2, 3
algorithm: bicubic
Inductive Probe
##[probe]
#pin: ~!PB7
#pin: PG15
#pin: ~!PC5
#x_offset: 0
#y_offset: 25.0
#z_offset: 0
#speed: 10.0
#samples: 3
Fan Control
#[fan]
#pin: PA8
#off_below: 0.10
Hotend Fan - FAN1
#pin: PE5
#max_power: 1.0
#heater: extruder
#heater_temp: 50.0
#fan_speed: 1.0
pin: PD12
heater: heater_bed
Exhaust fan - FAN3
#pin: PD13
#max_power: 1.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
LED Control
#pin: PB10
##Octopus PRO 1.1
#pin: PB0
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
[idle_timeout]
timeout: 1800
#gantry_corners:
-60,-10
310, 320
Probe points
#points:
50,25
50,175
200,175
200,25
#gantry_corners:
-60,-10
360,370
Probe points
#points:
50,25
50,225
250,225
250,25
#gantry_corners:
#-60,-10
#410,420
Probe points
#points:
#50,25
#50,275
#300,275
#300,25
#speed: 100
#retries: 5
#max_adjust: 10
[board_pins]
aliases:
# EXP1 header
EXP1_9=, EXP1_10=<5V>,
# EXP2 header
Displays
#[display]
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#pin: EXP1_1
#[display]
#lcd_type: uc1701
#cs_pin: EXP1_3
#a0_pin: EXP1_4
#rst_pin: EXP1_5
#contrast: 63
#pin: EXP1_6
#chain_count: 3
#initial_RED: 0.1
#initial_GREEN: 0.5
#initial_BLUE: 0.0
#color_order: RGB
#gcode:
Macros
[gcode_macro PARK]
[gcode_macro G32]
G90
G28
QUAD_GANTRY_LEVEL
G28
PARK
G32 ; home all axes
bed_mesh_clear
Bed_mesh_calibrate
voron_purge
line_purge
TURN_OFF_HEATERS
M107                                     ; turn off fan
BED_MESH_CLEAR
## <---------------------- SAVE_CONFIG ---------------------->
## model_coef = 1.893197358418992,
## 0.6793703046731926,
## -0.1408335310424842,
## 0.3420449523455563,
## -0.1595815189762197,
## model_domain = 1.9415886291284917e-07,1.9476376064813647e-07
## model_temp = 15.070651
Please follow what @EddyMI3D instructed you for posting your printer.cfg:
The big dump isn’t easy to follow.
printer (2).zip (5.7 KB)
Just doing a quick look at the file (thank you - but you don’t need to .zip it) - and I see that you still haven’t make the changes that @EddyMI3D suggested to you above.
Please Change the first two lines of your printer.cfg from:
to
That should resolve your problem and allow you to SAVE_CONFIG.
Thanks for that. I changed all as suggested and after beacon_calibrated I save_config. When I g28 it comes up with the message: No Beacon model loaded.
Did you follow the instructions here:
https://docs.beacon3d.com/quickstart/#3-install-beacon-klipper-module
Yes all done as per beacons instructions to the letter. For some reason klipper is not accepting beacon.
Can you post your latest 'klippy.log' and moonraker.cfg`?
Hello @pete1 !
Pleas do this:
klippy (21).log (73.5 KB)
moonraker.conf (2.7 KB)
printer (3).cfg (18.2 KB)
There are still two config blocks.
You may delete them both. Klipper should build a new config block.
