Voron tap endstop issues
Printer Model: Voron 2.4r2
MCU / Printerboard:Octopus v1.1
I have installed Voron Tap / BTT SB 2240 and completed all cfg files in Mainsail. I get the endstop popup menu to allow for endstop check. I can not for the life of me get the Z endstop to trigger with the lifting up of the stealthburner. I do get the red light when relaxed and the blue light once lifted.
any help would be greatly appreciated… I assume it is very simple. Also having issues with the tool head fan not turning on.
Any help would be greatly Appreciated!
I have added the printer.cfg and the btt_sb-2240.cfg
# This file contains common pin mappings for the BigTreeTech Octopus V1.
# To use this config, the firmware should be compiled for the STM32F446 with a "32KiB bootloader"
# Enable "extra low-level configuration options" and select the "12MHz crystal" as clock reference
# after running "make", copy the generated "klipper/out/klipper.bin" file to a
# file named "firmware.bin" on an SD card and then restart the OctoPus with that SD card.
## Voron Design VORON2 250/300/350mm BigTreeTech OctoPus V1 TMC2209 UART config
## *** THINGS TO CHANGE/CHECK: ***
## MCU paths                            [mcu] section
## Thermistor types                     [extruder] and [heater_bed] sections - See https://www.klipper3d.org/Config_Reference.html#common-thermistors for common thermistor types
## Z Endstop Switch location            [safe_z_home] section
## Homing end position                  [gcode_macro G32] section
## Z Endstop Switch  offset for Z0      [stepper_z] section
## Probe points                         [quad_gantry_level] section
## Min & Max gantry corner postions     [quad_gantry_level] section
## PID tune                             [extruder] and [heater_bed] sections
## Probe pin                            [probe] section
## Fine tune E steps                    [extruder] section
## Mainsail settings
[include stealthburner_leds.cfg]
[include btt_ebb-sb2240.cfg]
[include mainsail.cfg]
[exclude_object]
[mcu rpi]
serial: /tmp/klipper_host_mcu
##  Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_2B0040001750344D30353320-if00
restart_method: command
[input_shaper]
shaper_freq_x: 62
shaper_type_x: mzv
shaper_freq_y: 42
shaper_type_y: mzv
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000             #Max 4000
max_z_velocity: 15          #Max 15 for 12V TMC Drivers, can increase for 24V
max_z_accel: 350
square_corner_velocity: 5.0
#   X/Y Stepper Settings
##  B Stepper - Left
##  Connected to MOTOR_0
##  Endstop connected to DIAG_0
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
rotation_distance: 40
microsteps: 32
full_steps_per_rotation:200  #set to 400 for 0.9 degree stepper
endstop_pin: PG6
position_min: 0
##  Uncomment below for 250mm build
#position_endstop: 250
#position_max: 250
##  Uncomment for 300mm build
position_endstop: 300
position_max: 300
##  Uncomment for 350mm build
#position_endstop: 350
#position_max: 350
homing_speed: 25   #Max 100
homing_retract_dist: 5
homing_positive_dir: true
##  Make sure to update below for your relevant driver (2208 or 2209)
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.8
sense_resistor: 0.110
stealthchop_threshold: 0
##  A Stepper - Right
##  Connected to MOTOR_1
##  Endstop connected to DIAG_1
[stepper_y]
step_pin: PG0
dir_pin: !PG1
enable_pin: !PF15
microsteps: 32
endstop_pin: PG9
position_min: 0
##  Uncomment for 250mm build
#position_max: 250
position_max: 300
#position_max: 350
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: false
run_current: 0.8
#   Z Stepper Settings
## Z0 Stepper - Front Left
##  Connected to MOTOR_2
##  Endstop connected to DIAG_2
step_pin: PF11
dir_pin: !PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
##  Z-position of nozzle (in mm) to z-endstop trigger point relative to print surface (Z0)
##  (+) value = endstop above Z0, (-) value = endstop below
##  Increasing position_endstop brings nozzle closer to the bed
##  After you run Z_ENDSTOP_CALIBRATE, position_endstop will be stored at the very end of your config
#position_endstop: -0.5
#position_max: 210
##  Uncomment below for 300mm build
position_max: 260
##  Uncomment below for 350mm build
#position_max: 310
position_min: -5
homing_speed: 8
second_homing_speed: 3
homing_retract_dist: 3
[tmc2209 stepper_z]
uart_pin: PC6
interpolate: false
run_current: 0.8
##  Z1 Stepper - Rear Left
##  Connected to MOTOR_3
[stepper_z1]
step_pin: PG4
dir_pin: PC1
enable_pin: !PA0
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z1]
uart_pin: PC7
interpolate: false
run_current: 0.8
##  Z2 Stepper - Rear Right
##  Connected to MOTOR_4
[stepper_z2]
step_pin: PF9
dir_pin: !PF10
enable_pin: !PG2
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z2]
uart_pin: PF2
interpolate: false
run_current: 0.8
##  Z3 Stepper - Front Right
##  Connected to MOTOR_5
[stepper_z3]
step_pin: PC13
dir_pin: PF0
enable_pin: !PF1
gear_ratio: 80:16
microsteps: 32
[tmc2209 stepper_z3]
uart_pin: PE4
interpolate: false
run_current: 0.8
#   Bed Heater
##  SSR Pin - HE1
##  Thermistor - TB
[heater_bed]
##  Uncomment the following line if using the default SSR wiring from the docs site
heater_pin: PA3
##  Other wiring guides may use BED_OUT to control the SSR. Uncomment the following line for those cases
#heater_pin: PA1
## Check what thermistor type you have. See https://www.klipper3d.org/Config_Reference.html#common-thermistors for common thermistor types.
## Use "Generic 3950" for Keenovo heaters
sensor_type: Generic 3950
sensor_pin: PF3
##  Adjust max_power so it doesn't exceed the SSR rating. The Omron G3NA-210B-DC5 SSR is rated at 4 amps without a heatsink.
##  The formula is "4 / (Wattage_of_bed_heater / Mains_voltage) = max_power"
##  If max_power is greater than 1.0, use 1.0
max_power: 0.6
min_temp: 0
max_temp: 120
control: pid
pid_kp: 58.437
pid_ki: 2.347
pid_kd: 363.769
#   Probe
##  Inductive Probe
##  This probe is not used for Z height, only Quad Gantry Leveling
[probe]
activate_gcode:
    {% set PROBE_TEMP = 150 %}
    {% set MAX_TEMP = PROBE_TEMP + 5 %}
    {% set ACTUAL_TEMP = printer.extruder.temperature %}
    {% set TARGET_TEMP = printer.extruder.target %}
    {% if TARGET_TEMP > PROBE_TEMP %}
        { action_respond_info('Extruder temperature target of %.1fC is too high, lowering to %.1fC' % (TARGET_TEMP, PROBE_TEMP)) }
        M109 S{ PROBE_TEMP }
    {% else %}
        # Temperature target is already low enough, but nozzle may still be too hot.
        {% if ACTUAL_TEMP > MAX_TEMP %}
            { action_respond_info('Extruder temperature %.1fC is still too high, waiting until below %.1fC' % (ACTUAL_TEMP, MAX_TEMP)) }
            TEMPERATURE_WAIT SENSOR=extruder MAXIMUM={ MAX_TEMP }
## Select the probe port by type:
## For the PROBE port. Will not work with Diode. May need pull-up resistor from signal to 24V.
#pin: ~!PB7
## For the DIAG_7 port. NEEDS BAT85 DIODE! Change to !PG15 if probe is NO.
#pin: PG15
## For Octopus Pro PROBE port; NPN and PNP proximity switch types can be set by jumper
#pin: ~!PC5
#pin: PB5
x_offset: 0
y_offset: 0
z_offset: 0
speed: 10.0
samples: 3
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
#   Fan Control
##  Print Cooling Fan - FAN0
#kick_start_time: 0.5
##  Depending on your fan, you may need to increase this value
##  if your fan will not start. Can change cycle_time (increase)
##  if your fan is not able to slow down effectively
#off_below: 0.10
##  Hotend Fan - FAN1
#max_power: 1.0
##heater_temp: 50.0
##  If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
##  Controller fan - FAN2
#heater: heater_bed
##  Exhaust fan - FAN3
[heater_fan exhaust_fan]
pin: PD13
max_power: 1.0
shutdown_speed: 0.0
kick_start_time: 5.0
heater: heater_bed
heater_temp: 60
fan_speed: 1.0
#   LED Control
## Chamber Lighting - HE2 Connector (Optional)
#[output_pin caselight]
#pin: PB10
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
#   Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
##  XY Location of the Z Endstop Switch
##  Update -10,-10 to the XY coordinates of your endstop pin
##  (such as 157,305) after going through Z Endstop Pin
##  Location Definition step.
home_xy_position:150,150
speed:100
z_hop:10
##  Use QUAD_GANTRY_LEVEL to level a gantry.
##  Min & Max gantry corners - measure from nozzle at MIN (0,0) and
##  MAX (250, 250), (300,300), or (350,350) depending on your printer size
##  to respective belt positions
[quad_gantry_level]
##  Gantry Corners for 250mm Build
#gantry_corners:
#   -60,-10
#   310, 320
##  Probe points
#points:
#   50,25
#   50,175
#   200,175
#   200,25
##  Gantry Corners for 300mm Build
gantry_corners:
   -60,-10
   360,370
##  Probe points
   50,25
   50,225
   250,225
   250,25
##  Gantry Corners for 350mm Build
#gantry_corners:
#   -60,-10
#   410,420
##  Probe points
#points:
#   50,25
#   50,275
#   300,275
#   300,25
speed: 100
horizontal_move_z: 10
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
# EXP1 / EXP2 (display) pins
[board_pins]
aliases:
    # EXP1 header
    EXP1_1=PE8, EXP1_2=PE7,
    EXP1_3=PE9, EXP1_4=PE10,
    EXP1_5=PE12, EXP1_6=PE13,    # Slot in the socket on this side
    EXP1_7=PE14, EXP1_8=PE15,
    EXP1_9=<GND>, EXP1_10=<5V>,
    # EXP2 header
    EXP2_1=PA6, EXP2_2=PA5,
    EXP2_3=PB1, EXP2_4=PA4,
    EXP2_5=PB2, EXP2_6=PA7,      # Slot in the socket on this side
    EXP2_7=PC15, EXP2_8=<RST>,
    EXP2_9=<GND>, EXP2_10=<5V>
#   Displays
##  Uncomment the display that you have
##  RepRapDiscount 128x64 Full Graphic Smart Controller
#[display]
#lcd_type: st7920
#cs_pin: EXP1_4
#sclk_pin: EXP1_5
#sid_pin: EXP1_3
#menu_timeout: 40
#encoder_pins: ^EXP2_5, ^EXP2_3
#click_pin: ^!EXP1_2
#[output_pin beeper]
#pin: EXP1_1
##  mini12864 LCD Display
#[display]
#lcd_type: uc1701
#cs_pin: EXP1_3
#a0_pin: EXP1_4
#rst_pin: EXP1_5
#contrast: 63
#spi_software_miso_pin: EXP2_1
#spi_software_mosi_pin: EXP2_6
#spi_software_sclk_pin: EXP2_2
##  To control Neopixel RGB in mini12864 display
#[neopixel btt_mini12864]
#pin: EXP1_6
#chain_count: 3
#initial_RED: 0.1
#initial_GREEN: 0.5
#initial_BLUE: 0.0
#color_order: RGB
##  Set RGB values on boot up for each Neopixel.
##  Index 1 = display, Index 2 and 3 = Knob
#[delayed_gcode setdisplayneopixel]
#initial_duration: 1
#gcode:
#        SET_LED LED=btt_mini12864 RED=1 GREEN=1 BLUE=1 INDEX=1 TRANSMIT=0
#        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=2 TRANSMIT=0
#        SET_LED LED=btt_mini12864 RED=1 GREEN=0 BLUE=0 INDEX=3
#   Macros
[gcode_macro PARK]
    {% set th = printer.toolhead %}
    G0 X{th.axis_maximum.x//2} Y{th.axis_maximum.y//2} Z30
[gcode_macro G32]
    SAVE_GCODE_STATE NAME=STATE_G32
    G90
    G28
    QUAD_GANTRY_LEVEL
    G28
    PARK
    RESTORE_GCODE_STATE NAME=STATE_G32
[gcode_macro PRINT_START]
#   Use PRINT_START for the slicer starting script - please customise for your slicer of choice
    G32                            ; home all axes
    G90                            ; absolute positioning
    G1 Z20 F3000                   ; move nozzle away from bed
[gcode_macro PRINT_END]
#   Use PRINT_END for the slicer ending script - please customise for your slicer of choice
    # safe anti-stringing move coords
    {% set x_safe = th.position.x + 20 * (1 if th.axis_maximum.x - th.position.x > 20 else -1) %}
    {% set y_safe = th.position.y + 20 * (1 if th.axis_maximum.y - th.position.y > 20 else -1) %}
    {% set z_safe = [th.position.z + 2, th.axis_maximum.z]|min %}
    SAVE_GCODE_STATE NAME=STATE_PRINT_END
    M400                           ; wait for buffer to clear
    G92 E0                         ; zero the extruder
    G1 E-5.0 F1800                 ; retract filament
    TURN_OFF_HEATERS
    G0 X{x_safe} Y{y_safe} Z{z_safe} F20000  ; move nozzle to remove stringing
    G0 X{th.axis_maximum.x//2} Y{th.axis_maximum.y - 2} F3600  ; park nozzle at rear
    M107                                     ; turn off fan
    BED_MESH_CLEAR
    RESTORE_GCODE_STATE NAME=STATE_PRINT_END
# This file contains common pin mappings for the BIGTREETECH EBBCan
# Canbus board. To use this config, the firmware should be compiled for the
# STM32G0B1 with "8 MHz crystal" and "USB (on PA11/PA12)" or "CAN bus (on PB0/PB1)".
# The "EBB Can" micro-controller will be used to control the components on the nozzle.
[mcu EBBCan]
# serial: /dev/serial/by-id/usb-Klipper_Klipper_firmware_12345-if00
canbus_uuid: 73d675ea94f6
[temperature_sensor EBB_NTC]
sensor_pin: EBBCan: PA2
[adxl345]
cs_pin: EBBCan: PB12
spi_software_sclk_pin: EBBCan: PB10
spi_software_mosi_pin: EBBCan: PB11
spi_software_miso_pin: EBBCan: PB2
axes_map: z,-y,x
[resonance_tester]
probe_points: 100, 100, 20
accel_chip: adxl345
step_pin: EBBCan: PD0
dir_pin: !EBBCan: PD1
enable_pin: !EBBCan: PD2
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: EBBCan: PB13
sensor_pin: EBBCan: PA3
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
# sensor_type:MAX31865
# sensor_pin: EBBCan: PA4
# spi_bus: spi1
# rtd_nominal_r: 100
# rtd_reference_r: 430
# rtd_num_of_wires: 2
[tmc2240 extruder]
cs_pin: EBBCan: PA15
driver_TPFD: 0
run_current: 0.650
stealthchop_threshold: 999999
[fan]
pin: EBBCan: PA1
[heater_fan hotend_fan]
pin: EBBCan: PA0
heater: extruder
heater_temp: 50.0
# [heater_fan 4W_FAN0]
# in: EBBCan: PB14
# tachometer_pin: EBBCan: PB15
# tachometer_ppr: 1
#[bltouch]
#sensor_pin: ^EBBCan: PB8
#control_pin: EBBCan: PB9
## NPN and PNP proximity switch types can be set by jumper
[probe]
pin: ^EBBCan: PC13
#[output_pin PB5]
#pin: EBBCan: PB5
#[output_pin PB7]
#pin: EBBCan: PB7
#[output_pin PB6]
#pin: EBBCan: PB6
Could you please attach the klippy.log to your next post.
Only there are error messages to be found.
Looking at the config you posted you have 2 [probe] sections, comment out the one in EBB36 and include the pin in the printer.cfg [probe] section. That may help
Hi, some forward about you problem or solution?
I have maybe the same problem, I can’t do work TMC2240 in the extrusor.
printer.cfg (7.7 KB)
I have a BTT manta m8p with 4 TMC2240 (X,Y, Z and E)
Don’t know if it helps! Did you read Sensorless Homing with the TMC 2240 drivers
Good luck, hcet14
Thanks @hcet14, yes I read it, with that thread I achieved to move the X, Y and Z axes, but no luck with Extruder, the user in that thread uses TMC2240 only for X and Y (for Z, he uses TMC2208), for the extruder he uses a TMC2209, he does not use a TMC 2240 in the extruder.
In which way is a TMC2240 issue related to a Voron Tap endstop issue as discussed here?
Open a new post in the general discussion and provide the required information.
Sorry, I thought this would be some reference information to help me.
