Printer Model: Voron 2.4 R2
Host / SBC Raspberry PI
klippy.log (3.3 MB)
Getting closer to that first Voron Benchy. Sensorless homing is now working for X and Y axis.
Now for Z. I have TAP installed on the Stealthburner toolhead connected to an EBB36 with CANBus. So I understand that TAP will be the Z endstop. The indicator on the TAP is blue when at rest and red when I lift it. However, klipper doesent indicate a change in endstop status when I manually trigger it. Also, if I home all, the Z axis moves up until it hits the upper limit. It seems it should be moving down to trigger the TAP.
I haven’t been able to find an article that addresses configuring TAP with CANBuss. Any help is greatly appreciated.
