Printer Model: voron0.2
MCU / Printerboard:SKR mini E3 v2
When pasting code or config snippets use the code tags </> in the menu above
z_ hop can’t verify that the hop moves towards the negative value, but the Z zero of voron0.2 and the limit switch are at the maximum value of Z, that is, the bottom. This results in if the platform is at the bottom, and if z is configuredz_hop is 5, and then execute the G28 X0Y0 or G28. Even if Z has triggered the limit switch, z will continue to increase and move downward by 5mm, which will cause Z to exceed the travel and hit the frame.
z_hop向负值方向移动我无法验证,但是voron0.2 的Z归零和限位开关在Z的最大值,也就是最底部。 这样造成如果平台处于最底部,如果配置z_hop为5,然后执行归零XY或者全部归零,即使Z已经触发限位开关,但是z还会继续增加向下移动5mm,也就导致Z会超出行程,撞上框架。
