Endstop Z permanently triggered EBB36 Toolboard
Printer Model: CR10S PRO V2
MCU / Printerboard: MANTA M5P + EBB36 CANBus Toolboard
klippy (9).log (1.6 MB)
Hi all, trying to setup my CR10S PRO V2 with an EBB36 board and BLTouch Z probe.
I can get the X and Y axes to home successfully however these are attached to the Manta Board not the EBB. I cannot get the Z axis too home. The Z axis lowers a litttle bit but does not deploy the BL Touch and then stops and gives the klipper error ‘Endstop z still triggered after retract’ . I also cannot get the Part Cooling Fan to run when giving commands via the Klipper interface. Thoughts?
Thanks
Looking at your klippy.log, I don’t see where you’ve specified the [bltouch] parameter as defined here:
https://www.klipper3d.org/BLTouch.html
Now, you have set some aliases for the BL Touch and you have a [probe] parameter, but the pin argument in it doesn’t match the pins in the alias statement.
