I installed a Chaotic Lab Tap2.
After customizing I got an error message.
“Probe virtual endstop only as endstop pin”
Voron trident
Board Octopus Pro
Voron trident
Board Octopus Pro
You should post in the General Discussion sub forum and attach your current klippy.log.
Wie kann ich das Logfile hochladen. Bin neu hier.
gruß Roland
You can just drag’n’drop it into the edit field as well.
And please stick to English language here in the forum.
Found the error. There was a typo in the entry.
Now I have a new error. The tap is triggered even though it is in the down position. Light is blue, but limit switch Z and probe is triggered. How to rotate the direction. Normally all limit switches should be open.
Is this a connection error (cable) or is it in the printer config file
printer.cfg (16.6 KB)
I have attached my Printer.cfg.
Best regards
Roland
