Unable to detect tap: insufficient slope delta (-2671.302108 vs 2375.917000)
Printer Model: Voron Trident
MCU / Printerboard: SKR mini e3
Host / SBC: pi
klippy.log:
Recently recieved this error :
This occurs after issuing a “probe method=tap” command, or during initial homing. The printer can still rough home using the Eddy coil, but the tap command is now problematic. I have changed nothing, except a few klipper updates.
Using BTT Eddy Coil and Klipper Eddy Tap with some of Timofey’s macros. Sometimes it also throws a probe activated before touch error. I’m wondering if the probe is failing.
klippy (2).zip (1.3 MB)
I was unable to yield a proper result with the auto calibration routines for tap_threshold, and so I have implemented the tap_threshold:5000 in the config, higher than the refined auto cal of 3500 and things seem to be working
