Printer Model: Voron 250mm
MCU / Printerboard: SKR Mini E3 V3
Host / SBC: Pi4
klippy(3).log (2.6 MB)
I have a BTT Eddy Coil and want to use it with the tap function. I have configured the coil and calibrated it according to the docs, and also upped the drive current from 16(calibrated) to 17, as suggested at the end of the docs. I have recalibrated the probe after changing the drive current. The threshold calibration does not work for me, and returns errors everytime. I have manually calibrated the threshold level. When executing a “G28 Z” homing move, the printer returns a “probe triggered prior to movement” error but the printer still seems to behave as if the Z is homed. This error will interrupt a print_start routine. If I execute a PROBE METHOD=TAP it seemingly works fine. I am unsure how to respond to the error I am receiving.
