Printer Model: Sovol SV08
MCU / Printerboard: Stock
Host / SBC Built in
Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
Just moved to mainline on an SV08 with the Sovol eddy sensor. Started with eddy-ng, but switched over to the built-in probe support and disabled eddy-ng. Setup, calibration, and printing work fine. HOWEVER, after I finish one print, the next print fails while doing a z home. It will also fail if I try the z home manually. The error is “Probe triggered prior to movement”. After restaring the machine, I can print one time again before having to reboot. I figure there must be some configuration issue from the prior eddy-ng install that is affecting this. I’ve attached my macro and printer.cfg files in addition to the klippy log.
A quick scan of your klippy.log (which has the REAL printer.cfg in it) finds the following
your configuration still has [probe_eddy_ng eddy] section.
If you are using eddy tap as probe then [probe_pressure] is useless. Deleting it also allows you to get rid of klippy/extras/probe_pressure.py, klippy/extras/z_offset_calibration.py, AND the dirty flag.
Your [probe_eddy_current] section doesn’t have a tap_z_offset: defined. It defaults to 0.0 but a small offset may Be needed.
Your start_print macro seems okay but check your start g-code in your slicer for Sovol gibberish. I prefer to ONLY call the macro and delete everything else.
Thanks, I will look into safe_z_home and see if I can figure out where I need to do a z hop. What can’t figure out is why I don’t get this error after restarting the machine.
Nothing magic in this section, is simply storage for persistent info Klipper uses across multiple sessions. NEVER change a number but deleting a section won’t cause problems.
Tried the safe_z_home but then I couln’t use a homing_override so I just put the z home XY coords there. Found your BED_MESH_ADJ_FROM_TAP macros from another thread and worked them into my start print and removed a bunch of unneeded stuff. Working now. Thanks for the help and those macros.
Yes, I did remove [probe_pressure] and those untracked python modules so the install is clean now, but that did not solve the problem. I think the issue was having PROBE in the [homing_override] so I removed that, only calling PROBE from within START_PRINT.
