Just tried obico and deinstalled it.
Now on every startup of the printer, 5 error messages in the log ?
moonraker.log (742.3 KB)
I do not need a solution, I made a sd restore. Just for your info.
Well, the solution would have been easy and also could have been easily deducted from the error messages:
moonraker.conf
Obico
sectionSolution: Delete this config section from the moonraker.conf
If I touch Moonraker, the Updater shows red, something changed and need to go back to SW or HW… ? that also happen just on opening and closing the files.
I’m not sure what you are reporting.
~/printer_data/config/moonraker.conf
~/moonraker/
→ The conf
file is not “tracked” and thus could never mark Moonraker “invalid” in the sense of needing a restore.
You can mess up editing the file, but then Moonraker will no longer start. In any case, a soft or hard recovery does not touch the moonraker.conf
file.
If it does, then your installation is botched somewhere else.
