Another MCU shutdown
Printer Model: ChironWire
MCU / Printerboard: m8p + cb1
Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages,
klippy (11).zip (836.9 KB)
are covered there
… I have a modified Anycubic Chiron to a corexz. It’s my first time trying klipper so i ran into trouble. [Lost communication with MCU]
I tried flashing multiple times but the error persist all the time i print something. Stock power supply from the chiron, stock bed. Maybe someone can guide me to make this printer works. Thanks!
Your log indicate that it’s connection issues, try to replace USB cable
Change USB port, Introduce USB Hub with external power, etc …
I had this issue for a while. Started happening when I brought a second camera into the mix, even though they were both hooked up to the pi through a powered USB hub. Once I moved the USB to MCU cable to the hub also, the issue went away.
That’s a Manta board, with the CB1 piggybacking, there is no USB cable between the host and the MCU.
But at the end of the log bytes_retransmit increases.
Is the CB1 firmly inserted into the B2B connectors? Did you secured it with the heat-sink and screws? What’s the temperature of your CB1?
The only usb is that onw from the board to the hdmi display. It is with cb1 not pi
No camera connected. It’s with cb1 not pi so i don’t think it’s a usb problem
Yes the phisical conection between them is good. It runs around 50-55 celsius with heat-sink and 60mm fan
I failed to notice that part of your post… sorry.
I’m in the process of upgrading my printer (X5SA) to the same combo - M8p 1.1/CB1. when i first upgraded I was confused because the board was getting power, but couldn’t see the MCU…
I was afraid of breaking either one of those boards, but one of the connections was loose, or wasn’t seated correct. I think you really gotta seat those puppies in there. your connection might be intermittent; once things start moving, maybe the connection breaks. I -think- the connection that was loose in my case was the right hand one. I think BTT should provide torque specs with this board - so we know when its tight enough. :slight_smile:
