SV06 - MCU Shutdown - Can Someone Please Look At This Log?
Printer Model: Sovol SV06
MCU / Printerboard: Stock
Host / SBC- Raspberry Pi
Again, I’ve had a sudden MCU Shutdown and there’s no other explanation on the dashboard or notifications in Klipper.
Can someone take a look at the log file attached and see if you can see something? I’ve tried looking but don’t have any experience with the log files and haven’t been able to find a guide or tutorial.
thanks
logs-20241021-kLIPPY.zip (525.4 KB)
The last Gcode command was this:
G1 Z2.7 F21000
Quite fast for a Z-axes.
Yeah, would have have come from the slicer or the system settings?
Hard to say.
Maybe from the slicer. The wipe settings?
I just checked the gcode file for the model I printed right before this and it’s got that all through it since I’m printing PTEG:
;WIPE_END
G1 Z.65 F21000
that one printed fine, actually it’s printed beautifully and the settings were all the same in the slicer
The error Lost communication with MCU 'mcu' is typically not caused by odd gcode commands. See Timeout with MCU / Lost communication with MCU
Apart from this, Klipper luckily limits your z-movement velocity to max_z_velocity
