Printer Model: SV06
MCU / Printerboard: Stock
Host / SBC Raspberry Pi / Klipper
The only message I’m getting is
"Klipper reports: SHUTDOWN
Lost communication with MCU ‘mcu’
Printer is shutdown"
In the console it simply says "11:37 PM Klipper state: Shutdown "
Print was about 55% done - After firmware reboot the triangle icon next to the print run says “Klippy Shutdown”
I had restarted both printer and Raspberry Pi earlier this evening.
All software up to date including firmware flashed onto SV06
logs-20241016-234819.zip (2.4 MB)
Unfortunately I don’t have a clue looking at the logs and can’t find any online guide.
