Arduino nano + MPU 6050 error
Printer Model: Sovol Sv01
MCU / Printerboard: Fystec Cheetah v2.0
klippy (6).log (453.9 KB)
i’m trying to use Arduino nano + MPU 6050 to calibrate inpute shape, but i’m getting this error when i put the mpu6050 config below
[mcu nano]
serial: /dev/serial/by-path/pci-0000:00:1a.0-usb-0:1.5:1.0-port0
[mpu9250]
i2c_mcu: nano
i got this error then restat firmware
MCU Protocol error
This is frequently caused by running an older version of the
firmware on the MCU(s). Fix by recompiling and flashing the
firmware.
Your Klipper version is: v0.11.0-311-g9e765dae-dirty
MCU(s) which should be updated:
mcu: Current version v0.11.0-311-g9e765dae-dirty-20231106_172016-klipper-To-be-filled-by-O-E-M
nano: Current version v0.11.0-311-g9e765dae-dirty-20231107_004816-klipper-To-be-filled-by-O-E-M
Up-to-date MCU(s):
mcu ‘nano’: Unknown command: i2c_write
u guys know how to solve this problem ?
See MCU Protocol error caused by running an older version of the firmware
And please refrain from posting the same topic twice. I deleted the duplicate
Sorry about duplicate post, did not see it. About the problem, dont think the problem is older version of the firmware, cause they are the same version the diferrence between then is the time i flashed it.
You are probably right, the error message is misleading in this case.
Likely you modified the make files in a way that is now causing this error.
Git version: 'v0.11.0-311-g9e765dae-dirty'
Modified files: src/Makefile
Branch: master
Remote: origin
