Arduino uno shield CnC v3
Printer Model: none
MCU / Printerboard: Arduino uno; Shield Cnc V3
I did not find a cfg for this board, the bad thing is that I think the motors share enable and I don’t know if it is possible to use it with klipper,
In this case I am only interested in moving the motors, nothing more, since I want to try to make a CNC
Shared single enable pin is not an problem at all, most probably you can make klipper MCU firmware to run in Uno and drive 3-4 axis but not at very high speeds (depend on required stepping rate)
https://www.klipper3d.org/Features.html#step-benchmarks
I did spot similar project here: Drawing Robot - Arduino Uno + CNC Shield + Klipper by gwisp2 - Thingiverse
Thank you for the information
