Beacon Rev H Probe randomly disconnects
Printer Model: Ratrig V-Core 3.1
MCU / Printerboard: Raspberry Pi 4B (8 GB) + BTT Octopus v1.1 (F446)
I recently wired up the beacon rev H sensor to my Ratrig V-Core 3.1 and initially, all the calibration worked fine. However, when I ran BED_MESH_CALIBRATE, I had too many probe points set (100, 100 instead of 10, 10), so the printer scanned the bed and then Klipper shut down. I did a klipper/firmware restart and updated the bed mesh to only probe a 10x10 grid, but ever since, the beacon sensor isn’t being detected by Klipper. When I run ls /dev/serial/by-id/*, I only see the Octopus, even though I have the beacon USB cable connected to the pi.
I have not been able to successfully reconnect with the Beacon Sensor and am not sure what I need to do to fix this issue.
klippy.log (7.0 MB)
The Beacon is closed source and not part of mainline Klipper. You need to reach out to the creators of the Beacon for support.
