BED_MESH_CALIBRATE Ender 3 Pro
Printer Model: Ender 3 Pro
MCU / Printerboard: Creality 4.2.7
Whenever I use bed mesh calibrate, hot end sends the probe off of the bed without even reaching the far corner of the lower left of the bed (If you are facing the printer from the front). Below is my Printer.cfg file, can someone please help me.
This file contains pin mappings for the stock 2020 Creality Ender 3
Pro with the 32-bit Creality 4.2.2 board. To use this config, during
“make menuconfig” select the STM32F103 with a “28KiB bootloader” and
serial (on USART1 PA10/PA9) communication.
It should be noted that newer variations of this printer shipping in
2022 may have GD32F103 chips installed and not STM32F103. You may
have to inspect the mainboard to ascertain which one you have. If it
is the GD32F103 then please select Disable SWD at startup in the
“make menuconfig” along with the same settings for STM32F103.
If you prefer a direct serial connection, in “make menuconfig”
select “Enable extra low-level configuration options” and select
serial (on USART3 PB11/PB10), which is broken out on the 10 pin IDC
cable used for the LCD module as follows:
3: Tx, 4: Rx, 9: GND, 10: VCC
Flash this firmware by copying “out/klipper.bin” to a SD card and
turning on the printer with the card inserted. The firmware
filename must end in “.bin” and must not match the last filename
that was flashed.
See docs/Config_Reference.md for a description of parameters.
[include mainsail.cfg]
[include display.cfg]
[stepper_x]
step_pin: PB9
dir_pin: PC2
enable_pin: !PC3
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 220
homing_speed: 50
[stepper_y]
step_pin: PB7
dir_pin: PB8
enable_pin: !PC3
endstop_pin: ^PA6
position_endstop: 0
position_max: 220
homing_speed: 50
step_pin: PB5
dir_pin: !PB6
enable_pin: !PC3
rotation_distance: 8
position_min: -4
position_max: 250
[safe_z_home]
home_xy_position: 112, 128 # Change coordinates to the center of your print bed
speed: 50
z_hop: 10 # Move up 10mm
z_hop_speed: 5
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
gear_ratio: 42:12
rotation_distance: 26.359
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 23.561
pid_Ki: 1.208
pid_Kd: 114.859
min_temp: 0
max_temp: 300
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
tuned for stock hardware with 50 degree Celsius target
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
Pin mappings for BL_T port
[bltouch]
sensor_pin: ^PB1
control_pin: PB0
x_offset: -33.0
y_offset: -40.0
#z_offset: 0
probe_with_touch_mode: true
stow_on_each_sample: false
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 30, 30
mesh_max: 225, 225
probe_count: 6, 6
[display]
lcd_type: st7920
cs_pin: PB12
sclk_pin: PB13
sid_pin: PB15
encoder_pins: ^PB14, ^PB10
click_pin: ^!PB2
[board_pins]
aliases:
EXP1_1=PC6,EXP1_3=PB10,EXP1_5=PB14,EXP1_7=PB12,EXP1_9=,
EXP1_2=PB2,EXP1_4=PB11,EXP1_6=PB13,EXP1_8=PB15,EXP1_10=<5V>,
PROBE_IN=PB0,PROBE_OUT=PB1,FIL_RUNOUT=PC6
## <---------------------- SAVE_CONFIG ---------------------->
# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
# [bltouch]
#*# z_offset = 1.555
Please use the preformatted text tag for such code snippets to keep your posts clear and readable:
Agree to @LifeOfBrian
Without using that format, spaces and special characters get lost and the code is useless.
