Unknown command:"BED_MESH_CALIBRATE["
Printer Model: Ender3 V2 (Sprite Pro Extruder)
MCU / Printerboard: Stock Creality 4.2.2
Host / SBC: RPi 5 (used as linux computer with KIAUH)
KlippyLog.zip (153.8 KB)
I installed my new BLtouch onto my Ender 3 V2 recently, and although I have completed all of the steps, I repeatedly get the error:
Unknown command:“BED_MESH_CALIBRATE[”
I did a lot of research online, and it seems like the general response to that is that the [bed_mesh] section of the printer.cfg is missing or incorrect. In my case, I do not believe that either of these things are true, as I have copy-pasted other people’s sections into my config several times, and it appears in various places in the klippy log, though I don’t know how to read it’s syntax. I would appreciate it if anyone could help me, thanks.
Hello @Cython !
Why is there a [ at the end of the command?
Thanks for the reply,
The command it should be running is:
BED_MESH_PROFILE LOAD=default
but it doesn’t, and returns the error lsited above. I have also tried the alternative:
BED_MESH_CALIBRATE [METHOD=manual]
but it returns the same.
Please attach a new klippy.log to your next post.
You may try
BED_MESH_CALIBRATE METHOD=manual
The square braces describe the possible parameters you can use.
Referring to this:
https://www.klipper3d.org/Bed_Mesh.html#calibration
Thank you, this worked perfectly.
