Bed Mesh Error
Printer Model: Ender 3 lots of mods
MCU / Printerboard: 4.2.7
Host / SBC Pi
So for giggles and a learning curve I decided to try Cura slicer. … well now I have issues
The process I went through was to copy and save the entire klipper macro cfg file, then I replaced it with one designed around Cura. I made some other small changes as per various online guides to get cura and klipper to talk properly.
It went ok, printed a benchy, good stuff. But I found no benefit in using Cura and so because I know my way around Prusaslicer I decided to just stick with it.
So, I went back to my previous working macro cfg and my prusa setup, went to run a test print and I get the following errors just after the bed and extruder has reached temp and it starts the first pass of the bed meshing:
Internal error on command:“START_PRINT”
Internal error on command:“BED_MESH_CALIBRATE”
I know I’ve probably missed something or changed something I shouldn’t have, but I’m lost. Hopefully someone can see what it is.
I’ve done a full recalibration of the BD sensor, it sees the bed, printer does everything is should to get ready for a print … then nope.
I made no changes to printer.cfg
I bet it’s something simple and stupid.
Here’s my Macro.cfg - maybe I did something in there that I forgot?
# START PRINT
[gcode_macro START_PRINT]
    {% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(210)|float %}
    # Heat bed for probing
    M190 S{BED_TEMP}
    # Use absolute coordinates
    G90
    # Home the printer
    G28
    BED_MESH_CALIBRATE ADAPTIVE=1
    G1 Z5 F3000
     #KAMP Smart Park
    #Smart_Park
    # Set and wait for nozzle to reach printing temperature
    M109 S{EXTRUDER_TEMP}
     # Start printing!
    #KAMP Line Purge
    #VORON_PURGE
    LINE_PURGE
# END PRINT
[gcode_macro END_PRINT]
    M140 S0
    M104 S0
    M106 S0
    G91
    G1 X-2 Y-2 E-3 F600
    # Raise nozzle by 10mm
    G1 Z10 F1500
    G90
    G1 X10 Y200 F1500
    # Disable steppers
    M84
# HOMING G28 FOR BD SENSOR
[gcode_macro G28]
rename_existing: G990028
      {% if rawparams|length == 0 %}
           { action_respond_info("homing all") }
           G990028 X Y
           ## Homing with contactless probe with the homing_speed in [stepper_z]
           BDSENSOR_SET COLLISION_HOMING=0
           G990028 Z
           ## Homing with contact probe with the second_homing_speed in [stepper_z]
           BDSENSOR_SET COLLISION_HOMING=1
           G990028 Z
      {% else %}
            {% if 'x' in rawparams or 'X' in rawparams  %}
                 { action_respond_info("homing x") }
                 G990028 X
            {% if 'y' in rawparams or 'Y' in rawparams  %}
                 { action_respond_info("homing y") }
                 G990028 Y
            {% if 'z' in rawparams or 'Z' in rawparams  %}
                 { action_respond_info("homing z") }
                 G990028 Z
                 G990028 Z
# NOZZLE HEAT
[gcode_macro HEAT]
description: CYD_SCREEN_MACRO
  SET_HEATER_TEMPERATURE HEATER=extruder TARGET=200
    G1 Z10 F3000
# LOAD FILAMENT
[gcode_macro Load_Filament]
    SAVE_GCODE_STATE NAME=loading_filament
    M117 Loading Filament
    M83
    G92 E0.0
    G1 E40 F200  # Load filament into sprite and prime
    G92 E20
    RESTORE_GCODE_STATE NAME=loading_filament
# UNLOAD FILAMENT
[gcode_macro Unload_Filament]
    SAVE_GCODE_STATE NAME=unloading_filament
    M125 # park
    M117 Unloading Filament
    G91 # set relative
    G1 E10 F100
    G92 E0.0
    G1 E-10 F3000 # Unload filament from sprite 10mm
    G92 E-5
    RESTORE_GCODE_STATE NAME=unloading_filament
# PAUSE
[gcode_macro PAUSE]
rename_existing: PAUSE_BASE
    ##### set defaults #####
    {% set x = params.X|default(5) %}      #edit to your park position
    {% set y = params.Y|default(225) %}      #edit to your park position
    {% set z = params.Z|default(10)|float %} #edit to your park position
    {% set e = params.E|default(1) %}        #edit to your retract length
    ##### calculate save lift position #####
    {% set max_z = printer.toolhead.axis_maximum.z|float %}
    {% set act_z = printer.toolhead.position.z|float %}
    {% set lift_z = z|abs %}
    {% if act_z < (max_z - lift_z) %}
        {% set z_safe = lift_z %}
    {% else %}
        {% set z_safe = max_z - act_z %}
    ##### end of definitions #####
    PAUSE_BASE
    SET_IDLE_TIMEOUT TIMEOUT=40000
    G91
    {% if printer.extruder.can_extrude|lower == 'true' %}
        G1 E-{e} F2100
    {% else %}
        {action_respond_info("Extruder not hot enough")}
    {% if "xyz" in printer.toolhead.homed_axes %}
    G1 Z{z_safe}
    G90
    G1 X{x} Y{y} F6000
    {% else %}
    {action_respond_info("Printer not homed")}
# RESUME
[gcode_macro RESUME]
rename_existing: RESUME_BASE
    #### get VELOCITY parameter if specified ####
    {% if 'VELOCITY' in params|upper %}
    {% set get_params = ('VELOCITY=' + params.VELOCITY)  %}
    {%else %}
    {% set get_params = "" %}
    G91
    G1 E{e} F2100
    {% else %}
    RESUME_BASE {get_params}
# Filament Change
[pause_resume]
[gcode_macro FILAMENT_CHANGE]
    {% set X = params.X|default(50)|float %}
    {% set Y = params.Y|default(0)|float %}
    {% set Z = params.Z|default(10)|float %}
    SAVE_GCODE_STATE NAME=M600_state
    PAUSE
    G91
    G1 E-.8 F2700
    G1 Z{Z}
    G90
    G1 X{X} Y{Y} F3000
    G91
    G1 E-50 F1000
    RESTORE_GCODE_STATE NAME=M600_state
# CANCEL
[gcode_macro CANCEL_PRINT]
rename_existing: BASE_CANCEL_PRINT
    G91 # Set to incremental mode
    G0 Z10 F600 # raise extruder
    G90 # Set back to absolute mode
    TURN_OFF_HEATERS
    G0 X5 Y220 # clear print
    CLEAR_PAUSE
    #SDCARD_RESET_FILE
    BASE_CANCEL_PRINT
# RETRACTION LENGTH
[gcode_macro SET_RETRACTION_LENGTH]
  SET_RETRACTION RETRACT_LENGTH={params.LENGTH|float}
  GET_RETRACTION
klippy.log (575.1 KB)
You have BDSensor
v0.13.0-508-gbe1c97ff0
This should work, I think.
cd ~/klipper
git checkout 3c56eb7f6
sudo systemctl restart klipper
(If not, you can revert further one by one change with git checkout HEAD^)
Hope that helps.
-Timofey
Thank you, thank you, thank you… problem solved.
