Hi Everyone.
I have an Ender 6 upgraded with Antclabs BL touch + Octopus 1.1 board and Raspbery Pi Zero 2W Running Klipper. All this has been working like a charm for months.
Recently i am getting an weird issue.
When i start Klipper i get no errors.
If i do a STEPPER_BUZZ command on all 3 axes, everything is working as it should.
When i´m doing homing either Z or X or Y or ALL i see the bed lowering and receive an error on klipper that says:
MCU ‘mcu’ shutdown: Timer too close
This often indicates the host computer is overloaded. Check
for other processes consuming excessive CPU time, high swap
usage, disk errors, overheating, unstable voltage, or
similar system problems on the host computer.
Printer is shutdown
I already checked all cables and everything is ok. Tried alternative Pi with same results, then i decided to check the BL touch and noticed that it was not working as it should. When i turn the printer on i see the pin going up and down twice and stay red light but if i use BLTOUCH_DEBUG COMMAND=pin_down nothing happens, if i pull it out light goes off and do a pin_up also nothing happens, at this point if i do a BLTOUCH_DEBUG COMMAND=reset, i see the pin going up again and turn red.
This is probably the reason why Klipper is throwing the error.
I have diassembled it and cleaned the pin with isopropilic alcohol but did not help.
I have also checked the pins on the octopus and they match the ones on the config file.
Sending the Klippy log in advance.
Any help is apreciated.
klippy (2).log (1014.2 KB)
