Printer Model: AnyCubic i3MEGA-S custom
MCU / Printerboard:OrangePiPrime Armbian Bullseye server stable 5.15.y Sep 24, 2022+OctoPrint1.8.4+OctoKlipper (0.3.9.4)/BigTreeTech SKR2.0RevB
klippy.log (93.3 KB)
printer.cfg (4.0 KB)
BTT SKR2
BLtouch v3.1
G28 X Y → OK
**Error message
Send: G28 Z0
Recv: // Klipper state: Shutdown
Recv: !! Homing failed due to printer shutdown
Changing monitoring state from “Operational” to “Error”
Send: M112
Send: N2 M11235
Send: N3 M104 T0 S034
Send: N4 M140 S0*97
Changing monitoring state from “Error” to “Offline after error”
Connection closed, closing down monitor
**TEST
BLTOUCH_DEBUG COMMAND=pin_down → OK
BLTOUCH_DEBUG COMMAND=pin_up → OK
BLTOUCH_DEBUG COMMAND=touch_mode
QUERY_PROBE → OPEN
manual pin-up
QUERY_PROBE → TRIGGERED
changes I tried
I tried removing the leading # one by one, but all failed.
[bltouch]
sensor_pin: ^PE4
control_pin: PE5
x_offset:-0.5
y_offset:24.5
z_offset:1.2
#probe_with_touch_mode: True
#set_output_mode: 5V
#pin_up_touch_mode_reports_triggered: False
#stow_on_each_sample: False
Of course, without BLtouch, the printer works fine.
