Eryone ER20
MCU / Printerboard: Mks Nano v3.1
klippy (7).log (1.6 MB)
Hi, I have 2 bltouchs, the er20 original and a chinese brand, ive tried both and when i turn the printer on they light up and the pin goes through its test process
i try to run diagnostics and the pin will not move on both, i thought one is broken so tested with the other as well
i have wired them as per the board schematics and setup the klipper config, but get the error
Failed to verify BLTouch probe is raised; retrying.
BLTouch raise probe error: BLTouch failed to raise probe
double checked the wiring and im a bit lost now
tried 2 bltouch and 2 separate cables both the same also connected to z- on board
printer.cfg_1699301159866.zip (1.7 KB)
