Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Pasting yourprinter.cfgis not needed Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
I’m about to set up my printer config in my DIY modificated A8 printer. 12V set up.
Using a Creality Sprite extruder.
Everything works as it should except getting the heatbed and extruder heat to work.
Have measured heatbed and termistor both are OK, same with extrudercartridge and thermistor.
Hi ,
Thanks for your reply.
I’ve changed it to Generic 3950, but still same result, no heat. I also checked my hotbed. Measured the NTC to 100k and the plate to 0,001 ohm. So heatbed seems to be ok.
Any other ideas?
/Kent
Hi Sineos,
Replaced heatbed and extruder cartridge. Going for “Generic 3950”
Tripplechecked wiring. Also checked the ports.
Everything seems ok but still not getting 12 v to the heaters!?.
Using a 480 Watt 12 Volt PSU
Everything else is working.
I added a new log file, mayby it can help you to see whats missing.
Hope you can help?
When you make changes and a new klippy.log is required, the new log has to be attached to a new post and does not replace the one in the very first post. This messes everything up
I’m not so sure what you are reporting.
The log shows no traces of an activated heater, neither the bed nor the extruder.
Set appropriate temperatures for them and then attach a log if things do not work as expected.
In addition, use a digital multimeter set to volt to measure the output of your board’s heater connectors
I measured the HB when giving the command of 60 C. No voltage on the output. Same issue with HE0 (190 C).
I’ve checkt my extruder motor it’s working but not when connected to Motor M5. All the other motors are running as they should.
Also measured the cable for HB & HE0 it’s OK
Even measured my HB & HE0 again, both are OK.
Fuses are OK
There is 12V on the fan output
My PSU is 12V 480W
WiFi and screen works just fine so I guess that the CB 1 works as it should.
Could it be the board itself that is toasted???
This is my Bed heater section for a V0 with M5P board, pretty sure this is missing from your config (same with the extruder):
# Heated Bed
[heater_bed]
heater_pin: PA5
sensor_type: ATC Semitec 104NT-4-R025H42G
sensor_pin: PA0
max_power: 1.0 # Adjust Max Power according to 0.4w per square cm. Calculator available at https://tools.takuya.wtf/
min_temp: 0
max_temp: 120
control: pid
pid_kp: 60.453
pid_ki: 2.749
pid_kd: 426.122
And the extruder - but mine is CAN, so will setup a bit different if you don’t use a CAN toolhead.
