I had Klipper running on my CR10S for months, two weeks ago I decided to change to the BTT Octopus, and after some teething problems I have it up and running. But I am having issues readding the correct temperature with the thermistors. I didn’t have this problem with the Creality MB. I think I tracked it down to the Analog VRef being 0.100 volt too high. Klipper thinks the voltage is 3.3V when it is actually 3.2V. I made this determination by using the QUERY_ADC command and using fixed resistors to simulate the thermistors. As side note, I tried all the thermistor definitions with no luck, And keep in mind that I had Klipper working properly on the Creality MB. Thoughts? Thanks.
