Cant connect to moonraker after editing its file
Printer Model: Voron2.4
MCU / Printerboard: Octopus Pro
Host / SBC raspberry Pi3+
…The printer had just made a print, i.e. working normally. I decided to install KAMP. After adding In moonraker.conf,
[file_manager]
enable_object_processing: True
I can not connect because it gives this error:
Cannot connect to Moonraker (XXX.XXX.X.XX my IP address).
Without connecting I don’t know how to get the Klippy log, if it exists at all.
Can anyone help me?
See How-To Ask for Help for some guidance how to get the klippy.log
Think you dont need Kamp… Klipper has native support for Adaptative Meshing…
Thank You Sineos. I’ll take a look
klippy.log (446.3 KB)
I had to remove the date from the file name to be able to attach it
Solved.
I gave up on Adaptive Mesh.
I used the WinSCP program, located the Moonraker.conf file, and eliminated [file_manager] and
enable_object_processing: True.
The printer came back to life.
The Sineos tip was fundamental for me to discover WinSCP.
Thank you
