Cant get Ender 3 V3 SE z endstop config right
Printer Model: Ender 3 V3 SE
MCU / Printerboard: SKU pico
Host / SBC: Pi Zero w 2
I have been trying to connect the strain sensor/load cell hx711 module. I just don’t understand the config and the documentation About probe it says
[probe]
pin:
#   Probe detection pin. If the pin is on a different microcontroller
#   than the Z steppers then it enables "multi-mcu homing". This
#   parameter must be provided.
does that mean that it creates a virtual pin?
I have also tried [probe] and [load_cell] but I cant figure it out.
how can I config [load_cell_probe] and [stepper_z]endstop_pin ? Should I not be doing this?
Hello @lefixx !
Please attach the klippy.log to your next post - and not to (another) file server.
See here: How-To Ask for Help
clippy.log (123.3 KB)
edit: added full log
klippy(1).log (1.6 MB)
any other ender 3 v3 se config I have seen do not utilize the load cell or they do it somehow else
I think they use BL Touch to stepper_y endstop_pin: probe:z_virtual_endstop
But I haven’t read up/messed around with bltouch yet.
See
endstop_pin is already probe:z_virtual_endstop
and removing position_endstopdidn’t make a difference.
Error is still
Module [load_cell_probe] does not support `probe:z_virtual_endstop`, use a pin instead.
[probe] alone is not enough to specify a load cell since a load cell needs 2 pins defined. I has to interact somehow with [load_cell]
Is it possible that the [load_cell] and [load_cell_probe] are not for endstop and only for bed mesh?
You are right; this is not correct. It is a bit confusing as the load-cell stuff is pretty new, and some parts to ‘polish’ it are not yet fully integrated:
  • You have to define any unused pin on your main MCU as an endstop (it will not be used but needs to be configured).
  • You will need to set up some macros that take over the actual homing. Refer to Load Cells - Klipper documentation for the entire process and in particular to Homing Macros.
Sidenote:
According to what is known today, the HX711 is not a good candidate due to its low sample rate and high noise. YMMV.
Ah much better, I would have never guessed. Now I am getting
hx711 finished 'load_cell_probe' measurements
hx711 starting 'load_cell_probe' measurements
load_cell_probe: Forced sensor restart due to error
in klippy but at least now I can move on. Don’t have an oscilloscope to see if there is a signal so I think will not use the load cell for the time being.
edit: something is not right, I tried to manually put 3.3 V and it still gives errors
