Printer Model: K1c
I’m trying to change the filament runout routine. The K1C is a direct driven printer and when the filament sensor is triggered and the printer pause the job, it still has approximately 50cm of filament inside the tube.
I wonder if there is a way to change the M600, so after the filament sensor is triggered, the printer continues to print Xcm and only after that it will execute the filament runout routine.
Hello @Paulorfo !
We are missing some information…
That information that have been asked for in the template that you almost complete deleted.
Printer Model: K1C
MCU / Printerboard: Not applicable
Host / SBC: Not applicable
klippy.log: Not applicable
Thaks, I hope it helps
Try again - Take what you’ve posted and put in the requested data where you have put “Not applicable”.
Printer Model: K1C
MCU / Printerboard: This information is NOT relevant at all for the question posted
Host / SBC: This information is NOT relevant at all for the question posted
klippy.log: This information is NOT relevant at all for the question posted
There. This should help to clarify.
Now let’s wait for someone interested in trying to help out with a pós solution.
Going back to your original question:
Based on the information that you’ve provided, I am quite sure that the answer to your question is “yes”.
